GF Extensions (Deepstops)
Turtle
Post by Turtle »
My unit came with v1.29 - which I still have running (have not yet upgraded it).
Under custom functions I can set CF32 and CF33 - the GF Extension low and high values.
However, under the firmware version information it seems to state that GF Extensions are supported at v1.31.
Is this correct?
With v1.29 can I set the values, but they are not used? or are GF Extensions (Deepstops) used with v1.29
I will upgrade the machine shortly; just wondered if I am reading things correctly?
- Turtle
Recreational User/Tester
UK
Marou
Re: GF Extensions (Deepstops)
Post by Marou »
You can use GF extension in release V1.29 (CF32 and CF33)
of course you need to select a decotype with GF (ZH-L16 GF OC or ZH-L16 GF CC)
