Weird Default Setting - Gas Setup List - G1= 103/0
Hi all, Matthias,
Just did a firmware upgrade. After FW upgrade reset the CFs and Gaslist. Then went in to set my G 1 to 28%. Today I wanted to re-set it to 21% and was about to choose the "Default" setting. But the default setting reads
"Default: 103/0".
When I choose the default setting the gas ist set to O2 103%.
I can set the gas to 28% manually. But how can I fix the Default Setting.
Did three dives in the last two days and all works fine.
At the end of February I am off to Oz for some cave diving. Would be nice to have it fixed till then.
Re: Weird Default Setting - Gas Setup List - G1= 103/0
Default values can be changed via PC software. A reset in the Reset Menu will fix this, too.
Well cockadoodldoo, it did work. Though I already had tried that. Actually I have the suspicion it did happen while configuring CF's with OSTC Planner.
As usuall it probably was PEBKAC.
Ooops I think it was Diving Log. No CFIII there yet.
