OSTC3 - Info MOD & pO2 Max
ClaudeDive
Post by ClaudeDive »
[left][/left]
Would it be possible to add the info "MOD" of the gas used on display dive mode and simulation mode as in the example attached photo,
[left][/left]
The information "MOD" could appear on all pages of these two modes "dive" and "Simulation"
[left][/left]
[img]file.php?6,file=538,filename=OSTC3_-_MOD.jpg[/img]
[left][/left]
Thanks for your answer,
[left][/left]
[left][/left]
Cheers ;)
Re: OSTC3 - Info MOD
As with most of your proposals, yes: Yes, this would be possible. But we don't start coding all your requests at once, sorry.
ClaudeDive
[left][/left]
As for my other applications, I think simple to achieve including "Info Type of gas" - "MOD" - "Blue color for inactif aGF" and "Low Battery signal", I hoped an answer to the technical proposals for ameliorations for your customers and users of your OSTC3, possibly with a period of application and your priorities but that it could have been also a refusal with your justifications, but not an answer that is not one.
[left][/left]
I thought the technical proposals for ameliorations was a main element and a vocation of your Forum, sorry.
[left][/left]
[left][/left]
Cheers ;)
Serious divers know the MOD's of the common gases, write
it on the tanks and stick to their diveplan. Sorry but i
see no need for this kind of information on the display.
It's usefull to doublecheck when you configure the gases.
ClaudeDive
Hi Scubatinoo,
[left][/left]
Sorry but I see no more need to have informations " EAD / END " on the screen during diving
[left][/left]
The Sérious divers know the gases MOD's in their tanks but would like also the safety recall of the MOD of these gases on the screen Elevated much more easy to read and useful than " EAD / END " during diving.
[left][/left]
" MOD " also can help to doublecheck the gas used with the same display on the computer and on the tank,
[left][/left]
This does not prevent you to doublecheck all your parameters when you configure your gases and also stick to your diveplan.
[left][/left]
[left][/left]
Cheers ;)
Post by Rob »
> would be possible.
So you ar going to save the max ppO2 for each gas in the gaslist?
If not, the mod is useless becausse the mod of a decogas belongs to another ppO2 than the mod of a bottom-gas.
ClaudeDive
Re: OSTC3 - Info MOD & pO2 Max
hi Matthias,
[left][/left]
On screen display "Deco Mode", we could have two settings pO2 max:
[left][/left]
A setting for "Bottom Gas" with pO2 = 1.4 for example,
[left][/left]
A setting for "Deco gas" and "Travel Gas" with pO2 = 1.6 for example,
[left][/left]
This would avoid having to adjust the pO2 for each gas,
[left][/left]
The MOD will be calculate automatically with the selection "Gas Type": "Travel" - "Bottom" and "Deco".
[left][/left]
[left][/left]
Cheers ;)
I use 1.6bar for the bottom gas sometimes.
ClaudeDive
[left][/left]
No problem! as you know pO2 Max are adjustable from 1.2 to 1.6 bar.
[left][/left]
You set so the value that suits you,
[left][/left]
"MOD" above gas used is calculated on 1.6 bar like the value written on the bottle of gas.
[left][/left]
[left][/left]
[img]file.php?6,file=544,filename=OSTC3_-_MOD_pO2_Max.jpg[/img]
Cheers ;)
ClaudeDive
[left][/left]
Following a further request of this feature, ("PpO2 gaz bas max vs gaz de déco" > Ludo - August 21, 2014 18:00)
[left][/left]
Matthias, it would be great to do,
[left][/left]
[left][/left]
Cheers ;)
