New 1.40 firmware
New 1.40 firmware
Today, the new 1.40 stable firmware for the OSTC3 has been released: http://www.heinrichsweikamp.com/?id=162&version=en
This update is recommended for all users:
New in 1.40:
CHANGE: Minor language updates
NEW: Show a Safety Stop if enabled (Menu "Deco Parameters")
BUGFIX: dive profile recording issue in OC mode
BUGFIX: OSTC settings via USB issues
BUGFIX: CNS in deco planner
Please install the firmware using the "OSTC Companion" software.
Heute haben wir die neue OSTC3 Firmware v1.4 stable veröffentlicht: http://www.heinrichsweikamp.com/?id=162&version=de
Dieses Update ist für alle Benutzer des OSTC3 empfohlen:
Neu in der 1.40:
CHANGE: Sprach updates
NEW: Sicherheitsstop (Menü "Deko Parameter")
BUGFIX: Logbuchprobleme bei OC Tauchgängen (Nur beim download über den PC) behoben
BUGFIX: OSTC Einstellungen via USB
BUGFIX: ZNS im Deco Planer
Bitte die Firmware mit dem "OSTC Companion" Programm installieren.
Rougaille
Re: New 1.40 firmware
Post by Rougaille »
Hello Matthias,
FW 1.40 Update DONE !
The compas is not working anymore :
- Language : French.
- On the surface screen in compas display : blocked 120°
- in compas calibration menu the 3 directions are blocked at 15677
Best regards,
Rougaille
Try a reboot and/or battery remove/re-install.
Rougaille
Post by Rougaille »
Matthias,
I've done REBOOT.
I've removed & reinstalled the battery (wait for 1min)
> Same bug !
[img]http://img11.hostingpics.net/pics/133715photo2.jpg[/img]
[img]http://img11.hostingpics.net/pics/309403photo1.jpg[/img]
Something with your calibration. Try a "Reset All"
Rougaille
Post by Rougaille »
Reset All DONE
> Same bug.
Then this may be a hardware issue: Please contact us directly: info@heinrichsweikamp.com
Rougaille
Post by Rougaille »
Matthias,
It was working perfectly before the FW upgrade.
Do you have positive feedbacks after the 1.40 upgrade concerning compas ?
Rougaille.
Ludo
Post by Ludo »
Hallo zusammen,
Update to v1.40 done, thanks again for the safety stop ;)
No issue with the compass, working fine. And still looking forward to a graphical representation with bearings.
Ludo
hosch
Post by hosch »
Sorry Rougaille,...
I've updated and recalibrated my OSTC 3 right now. And the compas works fine...
