http://www.heinrichsweikamp.com/?id=162&version=en has the new 1.44beta for the OSTC3.
NEW: Update warnings every second
NEW: Show "Stop" in front of Safety Stop
BUGFIX: Start dive mode simulator in correct depth
BUGFIX: Surface interval was not displayed correctly in some cases
NEW: Store tissue load, date and time, surface interval, desat. time and nofly time every hour and reload them after battery change
NEW: Show clock in Apnea mode, minor layout changes in Apnea mode
NEW: Simplify gas change
And some smaller bugfixes and changes.
Please give it a try and post some feedback here into this thread.
Edit: Continue here: read.php?6,13601
New 1.44 beta firmware
Rougaille
Re: New 1.44 beta firmware
Hello Matthias,
I've found a small bug with this version.
Either in english or in french :
the "Set Name" function of OSTC Companion is replacing the 11th character by a "b" or "ß"
Example :
1234567890b 2345678
Tel 0033
0102030405
Thanks,
Rougaille.
Example :
1234567890b 2345678
Tel 0033
0102030405
Thanks,
Rougaille.
Rougaille
Matthias,
Another question :
Since Beta 1.41 we have a new display "NEW: Ceiling display (GF_hi based) in divemode"
> I can see in Simulator "Ceiling" increasing from 0.0 > x.x
Can you please explain the meaning of this "Ceiling" value ?
Thanks,
Rougaille.
Another question :
Thanks,
Rougaille.
> "Ceiling" value ?
It's the hard ceiling based on your GF_hi.
> "Ceiling" value ?
I can confirm this, will be fixed in the stable, of course.
hploch
can't change minutes and day, month, year in 1.44 beta
- ClaudeDive
[left][/left]
Already report this problem with with v1.41 on my OSTC3, it's impossible to update the date,
[left][/left]
And also when I hold the button "Enter" pressed, to try for changed the date, It blocks the display of seconds, which blocks the watch,
[left][/left]
Of course, when I release the "Enter" button, the clock continues to run, but the date has not changed!
[left][/left]
If we consider "hard ceiling" as backup's info > (backup ceiling) or (GF_hi ceiling)
[left][/left]
It would be nice to also have the info for decompression in progress "real ceiling" > (real ceiling) or (current ceiling) on same screen with display and colors clearly distinct,
[left][/left]
Info "real ceiling" linked directly to "runtime", the ascent rate and actual decompression of the dive during all ascent,
[left][/left]
Info "real ceiling" may allow to secure a control additional of these two parameters (ascent rate, deco stop)
[left][/left]
Excellent the improvement for change of gas,
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
