OSTC3 - Battery problem and info logbook
ClaudeDive
Post by ClaudeDive »
[left][/left]
At the end of my last dive my OSTC3 was at 4% before the end of the battery,
[left][/left]
With firmware V1.41,
[left][/left]
At home I want start up my OSTC3 >> Impossible - The white LED to the left of the screen does not flicker - the screen is black,
[left][/left]
I connect my OSTC3 to my PC - the red LED lights one time to the left of the screen who is black, I change LS14500 battery by a new battery purchased at Innodive, tested with a votmètre at 3.58 Volts.
[left][/left]
OSTC3 start up, I confirm new battery 3.6 Volts.
[left][/left]
The OSTC3 Screen display :
[left][/left]
- Battery: 3.423 Volts
[left][/left]
- Diving total : 49605 ! > see photo below
[left][/left]
- Logbook: 21 dives > I lost 40 dives.
[left][/left]
[img]file.php?6,file=563,filename=IMAG0709.jpg[/img]
The next day I want to start up my OSTC3 >> Impossible - The white LED to the left of the screen does not flicker - the screen is black,
[left][/left]
I connect my OSTC3 to my PC - the red LED lights one time to the left of the screen, I replace the 1 st new LS14500 battery by the 2 nd new purchased from another supplier, tested with a votmètre at 3.65 Volts.
[left][/left]
[left][/left]
[left][/left]
- Battery: 3.511 Volts
[left][/left]
- Diving Total : 49605 !
[left][/left]
- Logbook: no dive> I lost 61 dives.
[left][/left]
Matthias, thank you to tell me if it is possible to explain what happened with the first and the second battery,
[left][/left]
- How is it possible to test the battery capacity, not just the voltage?
[left][/left]
- Why Diving Total : 49605 on my logbook?
[left][/left]
- Why my logbook is emptied? My OSTC3 was connected to my PC.
[left][/left]
For info, already reported on a topic of Yeti42, I don't find very making safe from a mechanical point of view to have only one net of threading of just one turn on the battery lid for a diameter of approximately 12 mm
The lid's threading which is an important point for security of the sealing of the OSTC3 will deserve to be improved,
[left][/left]
What do you think for this point, can you do an action on this issue?
[left][/left]
Thank you in advance for these responses, Regards.
[left][/left]
Cheers ;)
Re: Battery problem and info logbook
Looks more then a hardware issue to me, this has nothing to do with the firmware 1.41, sorry.
Can you please contact us directly: info@heinrichsweikamp.com ?
ClaudeDive
[left][/left]
Thank you for the quality of service, to all the team and the quick sending,
[left][/left]
Cheers ;)
