Recently switched to diving an inspiration xpd vision. Using my ostc 2n as a back up. Over the weekend been diving, the ostc runs close to the Vision computer but is failing to count surface interval, show desat time or no fly time.
Repetitive diving seems to account for tissue loading as the ostc continues to follow the vision. This info, surface interval, no fly, desat time has always shown up when diving open circuit.
Dives are logged accurately in the memory. Running version 2.9.
Any thoughts appreciated.
ostc 2n surface info in ccr
Re: ostc 2n surface info in ccr
Anyone got any thoughts on this ??
I can't see why your unit does not show the surface interval after a dive. I tested this here in CCR mode and it's displayed just fine.
Do you have a 2N or 2C?
It's a 2n.
Looking in the log it shows desat time but this and the other details are not shown on the surface display , surface interval shows a few minutes then next time I look it's reverted to 00.00
I have the exact same problem!
I'm also using CCR-mode in version V2.90.
I didn't have the problem in the version I hade before (sorry can't remember wich version) and I always use it in CCR-mode.
Is this a bug or do we only need to change settings??
I don't have another computer to compare divetimes against, really hope this is just a bug in surface mode and not a more serious problem with the hardware or software that will get me/us into serious trouble.
ZNE
ZNE
can you post as much info about your settings as possible? I still can not confirm this here, sorry.
This is how it looks (With the 3.00 pre-release firmware) after a normal CCR dive.
[img]file.php?2,file=634,filename=OSTC.png[/img]
