First gas active - Air
[img]file.php?2,file=642,filename=1.png[/img]
[img]file.php?2,file=643,filename=2.png[/img]
Second gas is inactive.
[img]file.php?2,file=644,filename=3.png[/img]
2N Wrong inactive gas color v2.90
OSTC 2N 4689
Re: 2N Wrong inactive gas color v2.90
Making second gas active:
[img]file.php?2,file=645,filename=4.png[/img]
And the result is:
[img]file.php?2,file=646,filename=5.png[/img]
Which you can see on first screen also:
[img]file.php?2,file=647,filename=6.png[/img]
And the result is:
OSTC 2N 4689
But in the simulator the gas is shown propperly:
[img]file.php?2,file=648,filename=7.png[/img]
And it is possible to change the gas:
[img]file.php?2,file=649,filename=8.png[/img]
But after returning to gas setup menu, second gas is still shown as inactive:
[img]file.php?2,file=650,filename=9.png[/img]
The same goes with other inactive gases. Their color becomes yellow only when they are set to be the first gas.
OSTC 2N 4689
- ClaudeDive
you need to define a depth change and the gas will be active,
[left][/left]
[left][/left]
[left][/left]
[left][/left]
Yes, but didn't learn it as a poem. Should have done it...
OSTC 2N 4689
