OSTC3 - Forums to split OSTC 3 and OSTC LE SPORT
ClaudeDive
Post by ClaudeDive »
[left][/left]
More and more messages are about OSTC LE SPORT.
[left][/left]
In order to keep a good quality playback of the informations and and do not drown the requests for the both computers,
[left][/left]
Could you split the "OSTC FORUM" into OSTC 3 and OSTC LE SPORT.
[left][/left]
Thank you in advance,
[left][/left]
Cheers ;)
ClaudeDive
Re: OSTC3 - Forums to split OSTC 3 and OSTC LE SPORT
[left][/left]
Although OSTC2 and OSTC3 are close by their casing, their uitilisations and concerns of users are quite different with the gases used and the depth zone,
[left][/left]
For these reasons it would be desirable for more clarity for all users to split the "OSTC3 and OSTC LE SPORT" forun" with better quality of processing for requests and informations,
[left][/left]
Thank you in advance for your reply,
[left][/left]
[left][/left]
Cheers ;)
ClaudeDive Wrote:
> [left][/left]
> clarity for all users to split the "OSTC2 and
> OSTC3 forun" with better quality of processing for
These forums are separated since months. I think you mean OSTC Sport and OSTC3? We'll see if a forum split is required. OSTC3-only forum was quite calm anyway.
ClaudeDive
Matthias thank you for your answer, of course I'm talking about "OSTC3 & OSTC LE SPORT", I have corrected my last post but the request was in the title,
[left][/left]
You say "OSTC3-only forum WAS quite calm anyway"
[left][/left]
But I think the OSTC3 forum might be less calm if applications "OSTC LE SPORT" was not "drown" the OSTC3 requests and those for which it is not easy to get answers,
[left][/left]
The risk of not separating the forums for OSTC3's users is the number of requests "OSTC LE SPORT" which does not usually concern OSTC3 users, That which will also for effect to slow down the evolution and improvement of OSTC3,
[left][/left]
[left][/left]
Cheers ;)
baking_bread
Post by baking_bread »
I think OSTC Sport and OSTC3 are more similar then intend B)-
I have successfully installed the Sport firmware on my OSTC3!
Sport firmware runs on the OSTC3 but not vise-versa. Make sure to check the settings before diving with the sport firmware on the OSTC3...
