Hallo zusammen,
wie der Titel schon sagt soll hier eine Positiv/Negativliste für Bluetooth Sticks entstehen, damit jemand der noch keinen hat sehen kann was er kaufen kann und wo er besser die Finger weglässt.
Bitte hier nur posten was funktioniert und was nicht, keine langen Diskussionen.
Informationen:
Betriebssystem
USBStick
this post is for collecting a list of Bluetooth sticks that are working with the OSTCSport and sticks that causes problems.
Please no long discussions, just postings what works and what doesn't work.
Ich fange mal an/ I'm starting with ------------------------------------------
working/funktioniert ---------------------------------------------------------
Windows7 64bit ---------------------------------------------------------------
Microsoft Wireless Presenter Mouse Bluetooth Stick
creates COM4 and COM5
COM4 works
DOES NOT work/ funktioniert NICHT --------------------------------------------
Linux Ubuntu 64bit -----------------------------------------------------------
Linux Ubuntu 32bit -----------------------------------------------------------
best regards / Grüße
OSTC Sport - Bluetooth Stick - Positiv/Negativliste - working/not working
Home: http://www.angermayr.eu
email: ostctools@angermayr.eu
Karsten
Re: OSTC Sport - Bluetooth Stick - Positiv/Negativliste - working/not working
Ultron UBA-140 4.0 Nano USB Adapter
Sitecom CN-524 4.0 USB Adapter
Sputnik
Asus BT 400
Linux Mint/ Ubuntu 64bit
Asus BT 400
Hama 3.0
Asus BT 400
Hama 3.0
Windows7 x64
Hama 3.0
Asus BT 400
Asus BT 400
Hama 3.0
Asus BT 400
Hama 3.0
Windows7 x64
Hama 3.0
guyloup
Worked fine with ASUS BT400 and windows 7
bnies
WORKING:
- MacBook Pro 13" Retina, Mid 2014
- Built-in bluetooth (Broadcom 20702B0)
- Mac OS X Yosemite 10.10.1
- OSTC Companion 1.134
- Device /dev/tty.OSTC####-SPP
HKu
As Karsten noticed earlier. It's probably not working with any desktop hardware configuration.
The Sport can be added manually, only a n outgoing comport created (COM11 in my case). Companion v1.134 message: Unable to open port.
Works/funktioniert ---------------------------------------------------------
On COM9
On COM9
HKu
Sitecom CN-524 4.0 USB Adapter (v2.0)
Sputnik
I had found that the Asus BT-400 works also on Linux Mint
The problem is to establish a working rfcomm connection
It works with the command
sudo rfcomm -i hci0 connect rfcomm0 00:90:25:4B:10:10
00:90:25:4B:10:10 is the MAC Adress of exampel OSTC
You have just to ensure that the connection does not hang up or is disconnected, because the working distance of/to the adapter is very short. Try to repaet the command till you have the right output, otherwise the distance is to far or bad:
Connected /dev/rfcomm0 to 00:90:25:4B:10:10 on channel 1
Press CTRL-C for hangup
if you see
Disconnected
you have to repeat becuase the connection is bad to far or similar.
I think it works altough with more adapters
I tried it with CSR 4.0 and with the Asus BT-400
if you see
Disconnected
Sputnik
Asus BT 400
AUKRU / CSR 4.0
Hama 3.0
Hama 3.0
Windows7 x64
Hama 3.0
Asus BT 400
AUKRU / CSR 4.0
Hama 3.0
Hama 3.0
Windows7 x64
Hama 3.0
algo
working fine / funktioniert:
Apple Macbook Pro Mid 2010 15"
built in Bluetooth (Broadcom 2070B0; Firmware v42 c846)
OS X El Capitan 10.11
OSTC 2
/dev/tty.OSTC10139-SPP
OSTC 2
