Hi
Does anyone know what the accuracy and the sampling rate for the pressure sensor and temperature sensor on the OSTC range of computers is? Is it the same across the board? Is the sampling rate adjustable?
Is every bit of data sampled recorded in the logbook or just used for the deco calculations?
I have looked through the manual for the Sport and googled it but cannot find this info.
Sampling rate
Re: Sampling rate
Sampling rate is 2s (default) and this is good for several hundred dives.
The "sport" logbook format is almost identical to the OSTC3: https://bitbucket.org/heinrichsweikamp/ ... at=default
Re: Sampling rate
Thank you Matthias
Is this the same for all current HW computers?
Re: Sampling rate
This is valid for the cR, Sport and OSTC3. The OSTC2 is different, here the sampling and storing is (again) highly user-configurable.
