The new OSTC3 and cR firmware 1.76 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
CHANGE: aGF pair has same range then normal GF pair
BUGFIX: Always update CCR sensor data in Sensor-Menu
NEW: Graphical compass display in dive mode
NEW: Bearing option in divemode
CHANGE: New warning icon
OSTC3 and cR: New 1.76 firmware released
Re: OSTC3 and cR: New 1.76 firmware released
Thanks for this update !
Can you explain what is "NEW: Bearing option in divemode" ?
Rougaille
Rougaille
If you have the compass display active, select "Bearing" with the left button and confirm with ENTER.
[img]file.php?6,file=701,filename=baering_OSTC.png[/img]
The new bearing will be saved and visible on the compass scale.
[img]file.php?6,file=702,filename=bearing_set_OSTC.png[/img]
Great !
Thanks.
Thanks.
- ClaudeDive
hi,
[left][/left]
Well done & thank you to "Jak" & Mathias for this beautiful version of compass, simple, clear & with a direction storing,
[left][/left]
[left][/left]
[left][/left]
[left][/left]
[left][/left]
Continue here: read.php?6,14765
