OSTC Sport: New Firmware 10.16
The new OSTC Sport firmware 10.16 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
CHANGE: Range of Custom GF_lo now from 20 to 95
CHANGE: Automatically abort connection fail after 2mins
BUGFIX: Fast Gas change near the ppO2 limit could cause switching to a non-available Gas #0
BUGFIX: There was a 1:4096 chance that a portion of a dive was not stored correctly resulting in download issues
Re: OSTC Sport: New Firmware 10.16
I have updated new firmware 10.16 yesterday and had dives today.
I try to upload divelog with Subsurface 4.4.2 and have the attached screenshots problem. The Sport connected to my macbook with following
Starting ...... Done
Download mode enabled
once download processing in about half,
the computer prompt Exited and restart
the Subsurface prompt up an error "Dive Data import error"
I do try Macdive to import and has error too.
Thank you for your help and please find attached files for reference.
vieux singe
Exactly the same problem here... I'm glad at least it's not a problem with me!!!
Hi all
I made dives with 10.15 then updated to 10.16 and then download to the computer.
All without problems. But...i first had to clear all bluetooth connection infos of ostc and had to connect like i did the first time.
This was what I did before post to here.
"did few times to clear all bluetooth connection and infos as well as delete pairing then re-pair again. no luck at all."
finger Wrote:
> Hi all
finger Wrote:
> Hi all
I did revert back to firmware 10.15.
Then I tried upload those divelogs again (those dives were taken after updated to 10.16), however, there was no luck, same upload in the middle then exited and disconnected bluetooth.
Therefore, it might be problem on firmware 10.16 crashing divelog files.
I have exactly the same problem with DiveMate (Android)X(
Norddeutsch
Exactly the same problem here... dowmloading to Subsurface doesn´t work!
Ok... :S
I got the message - and will dig into this issue immediately. Don't panic, your dives are stored safely and you'll be able to download them again.
So , i came for same problem , waiting matthias solution
This is now fixed and will be released after some testing tomorrow.
Hello Mathias,
thanks for your support! (tu)(tu)(tu)
-D
thanks for the hard working.
> testing tomorrow.
> regards,
> testing tomorrow.
> regards,
Continue here: read.php?6,14982
