New 3.03 Firmware
New 3.03 Firmware
Today, we released the 3.03 stable for the OSTC2 Series (2N/Mk.2/2C). The first line was missing sometimes in the logbook details view.
Updating is very easy if you have 1.90 or later and using Windows.
1. Get new bootloader v2: http://www.heinrichsweikamp.com/?id=145&version=en
2. Follow the step-by-step instructions: http://www.heinrichsweikamp.com/?id=117&version=en
Heute haben wir die Version 3.03 stable für die OSTC2 Serie (2N/Mk.2/2C) veröffentlicht. Im Logbuch fehlte manchmal die erste Zeile in der Detailansicht.
Das Updaten auf die neue Version ist sehr einfach, wenn bereits 1.90 oder später installiert ist und Windows verwendet wird.
1. Neuen bootloader v2 herunterladen: http://www.heinrichsweikamp.com/?id=145&version=de
2. Die einfache Schritt-für-Schritt Anleitung befolgen: http://www.heinrichsweikamp.com/?id=117&version=de
Viele Grüße/Best Regards,
Re: New 3.03 Firmware
ich kann die Version nicht downloaden. Ich bekomme immer die 302.
Kai
Kai
Hallo Kai,
Vielleicht warst Du etwas zu schnell. Jetzt sollte es aber gehen.
narcosis deep
I can not upgrade 3.03 because after updating firmware 3.02, the ostc 2n is no longer seen by the computer (Windows or Mac is indifferent)
Drivers are properly installed
I tried changing USB cable, nothing.
I tried changing the USB port, nothing.
what can I do?
when I connect the OSTC to the PC only charge the battery.
thanks
regards
Massimo
what can I do?
thanks
regards
Massimo
Hi.
Considering the fact that there's new OSTC2 will the os be developed concurrently for both devices - the old and the new one?
If yes, for how long?
OSTC 2N 4689
Yes, of course.
How long? - As long as it's required.
Yes, of course.
Great work, as always. I haven't had a chance to do the upgrade yet, as I've been too busy working or diving (too much of the former, not enough of the latter).
Notwithstanding the compass, I noticed that the display on the website for the 2 looks quite different to the 2c.
Is there a new look? If there is, is it limited to the 2 or does the 2c get it/will get it?
Tony.
Tony.
Der Frage von Tony schliesse ich mich an und ergänze sie wie folgt:
Ist denn ein technisches upgrade des 2c auf den 2(neu) möglich, so in der Art: USB raus, Bluetooth und neue Bodenplatte rein ?
MfG
Olaf
MfG
Olaf
OSTC 2c # 9158
Hallo Olaf,
Die Elektronik ist doch sehr unterschiedlich und sogar das verwendete Display ist ein anderes. Ein Upgrade ist daher nicht möglich oder wäre sehr aufwändig.
Matthias...what about my question with regards to the different graphics? Is that also not possible?
Some features from the new layout will be in the OSTC 2C/2N and Mk.2.
Thanks Matthias.
I look forwards to getting them onto the computer
Can you expand on which graphical features made it into the 2C? I finally got around to putting 3.03 on last night and at least out of the water, I can't tell any visual difference.
He said "Some features from the new layout will be in the OSTC 2C/2N and Mk.2", that means in the future and not in the current firmware.
You see that isn't how I personally interpreted what he said...I read it thus: "Some of the features will be in the OSTC 2C/2N and Mk.2 but not all of them", otherwise the wording would have been "Some of the feature will be in the OSTC 2C/2N and Mk.2 in the future, but not all of them."
However you seem to know more than me, so I shall defer to your knowledge.
All i can say is what i've seen so far (I don't have any insider knowledge) and 3.03 looks identical to previous releases as far as i can see.
Toni, most writers here are not nativly english / british so bear with us please and don't try to read inbetween the lines.
Prof.Baltazar
I am having trouble installing the latest software. I do not know what my current version is. How can i find this info, and is it possible to upgrade to ver 3.03 regardless of the current installed version?
thanks
Roy
thanks
Roy
Hi Roy,
The current firmware is shown in the first line after starting the OSTC. In the surface mode, of course.
Please check this step-by-step info on how to update: read.php?2,4071
Prof.Baltazar
hehe...yes, I found it. Silly me. But i was not able to upgrade using OSTCS planner like i used to. I had to download last version og Subsurface and use this for the upgrade.
RE
RE
HI guys i am new to this forum
i have the 2N and very very happy with her
i know the 2c has a compass gut if i update the firmware will this feature be on my 2N
cheers for info
cheers for info
Hi Grubber
Welcome to the community
No, your 2N will never get the compass feature due to the missing hardware part...
Hello I have just updated to 3.03
I cant seem to turn on the computer on unless I have it underwater ?
has the button sensitivity changed?
Have you any advice ?
2C/2N OSTC's buttons are set hard-wired in hardware. No option to adjust this and it's not possible to add one.
