Hello
I have an OSTC 2N since some years ago and now I also got a new OSTC 2.
I am, as a ccr diver, missing a feature that is really good on the OSTC 2 N.
It is on the matter of always knowing your ppO2. In the OSTC 2 N you get the current ppO2 listed on the screen. I really miss that in the OSTC 2/hwOS.
Is it possible to put this information in dive mode, at least in ccr mode?
Please take a look at the picture if it's unclear what I mean.
Henrik
ppO2 hwOS - OSTC 2
Re: ppO2 hwOS - OSTC 2
[img]file.php?6,file=718,filename=OSTC_2N_ppO2.JPG[/img]
This is the ppO2 if you would Bailout to your current diluent gas. This is, for sure, something that could be integrated into the hwOS firmware.
Hello Matthias and the OSTC Team
Thank you very much for adding the feature of ppo2!!
If it's possible, at least for me, it would be a little bit better if you could put the ppo2 info on the same page as EAD/END.
I made a print screen to show my idea.
For me it is of big importance to see all three infos on the same display.
Henrik
(who has no problem connecting and using ostc2 with bluetooth with win 8.1 but with win10
(Does it matter in what order you install Subsurface, Divelog and OSTC Companion - because of .NET or drivers??)
(You forgot to post news of the new FW 1.87)
Henrik
Hi Henrik,
Did you try to turn the "Always show ppO2" to Yes under ppO2 Settings?
This would put ppO2 into the first warning message position so that way you can keep your EAD/END custom screen displayed together with the ppO2 value.
Regards, Janos
Regards, Janos
Hi Henrik, the order does not matter.
