Setpoint OSTC2
tomi
Setpoint OSTC2
I have OSTC2 and fw 1.93. I made a CCR dive with settings setpoint SP1=0,70 and SP5=1,30(at 21m). I use auto setpoint. At begin of the dive (at 6m) I noticed a red warning at left bottom corner of dive computer. It showed 0,00 bar. I had to change manually the setpoint to 0,70 and the auto setpoint didn't work at 21m. How is it possible to have 0,00 bar in dive computer?
Re: Setpoint OSTC2
I don't think I can help you with this but just out of interest, what is your setup for SP2, SP3 and SP4?
tomi
Re: Setpoint OSTC2
Those setpoints are default ones: SP2=0,90 SP3=1,00 SP4=1,20
And all of them set to 0m
Re: Setpoint OSTC2
Check Menu -> CCR Setup -> CCR Mode . It must be set to "Auto SP" or "Fixed SP" if you are not using sensors (Only available with the OSTC3 or cR).
Then, check your setpoints "Fixed Setpoints" SP1 - SP5
tomi
Re: Setpoint OSTC2
OTSC has set to AutoSP before the dive and all SP1-SP5 were correct.
Somehow it changed it to 0,00 bar at begin of dive
Re: Setpoint OSTC2
If you start the simulator now, does it start with SP1 as designed?
Re: Setpoint OSTC2
I think I may have found the issue here. SP1 may not be selected automatically in some cases for Auto-SP mode. Will be fixed asap.
