OSTC Sport: New Firmware 10.23
The new OSTC Sport firmware 10.23 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
Changes since 10.20 (Changes since 10.22):
CHANGE: Show velocity from 3m/min or more (Ascend or descent)
NEW: Segmented speed graph in divemode (optional)
NEW: Variable speed (7-20m/min) depending on depth (optional)
NEW: Logbook marker can be set in dive mode menu
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =10.22
CHANGE: button hold-down will increase values or move the cursor automatically (again)
BUGFIX: Bluetooth communications issues
NEW: Option to rotate the screen
WE
Re: OSTC Sport: New Firmware 10.23
Which PC program do you recommend to change the safety stop parameters on the Sport?
Walter
Walter
There is no software supporting this currently. I quite sure it will be available in e.g. "subsurface" or "Diving Log" soon.
vieux singe
10.23 loaded on my OSTC sport, dont see where these options can be set. Can you please let me know? Tks Rgds
screech
> (optional)
> know? Tks Rgds
In french menue
-Reglages
-prefer.reglages
-suite
> (optional)
> know? Tks Rgds
In french menue
-Reglages
-prefer.reglages
-suite
guyloup
Hi matthias. Nice upgrade with the ascent graph. In simulation mode, I see a small graph with 3 blocs ( white if I remember correctly) and 2 red blocks.
I understand that the red means "too fast ascent" but can you give an idea about the "scale" on the bar graph.
I hope, my question is clear
vieux singe
@ screech
Tks, appreciated.
Tks, appreciated.
guyloup
Hi ,
Does ths speed options taken foer the OSTC 2 apply to the sport?
The latest (beta for OSTC2, cR and OSTC 3) has both: Speed in m/min and the graph. This is the latest speed table:
; use a depth-dependent ascent rate warning
; depth(m): 6 >12 >18 >23 >27 >31 >35 >39 >44 >50
; speed(m/min): 7 8 9 10 11 13 15 17 18 19 20 (warning)
; speed(m/min): 5 6 7 8 8 10 12 13 14 15 15 (attention)
This is currently not configurable. It can be toggled between fixed 10m/min warning and the above table only.
RKD62
Thanks for this great new functions! (tu)
guyloup
May I point out the 2 questions above that have not been answered? If my questions are not clear or have no purpose, please let me know.
Thank you.
Thank you.
Brookes
Hi guyloup,
I think your questions need a little patience. Right now is the "Boot 2016", which is germanys biggest dive exhibition and I guess the whole team is there right now until sunday.
guyloup
Thank you brookes. Did not know that.
guyloup Wrote:
> Hi ,
> to the sport?
Yes, it's the same.
> >50
> (warning)
> (attention)
> Hi ,
> to the sport?
Yes, it's the same.
> >50
> (warning)
> (attention)
guyloup
Thank you for the answer MAtthias.
Just one question, to make it clear: On the graph bar: attention would be one red bar and warning 2 red bars?
CarstenB
Die neu Firmware funktioniert super, die Variable Geschwindigkeit ist sehr gut,
Jedoch habe ich eine Frage zum Geschwindigkeitsgraph,
Ist es richtig, wenn dieser eingeblendet wird, das dann die Auf- und Abstiegsgeschwindigkeit nicht mehr numerisch angezeigt wird?
Sinnvoll wäre es wenn die Geschwindigkeit rechts neben dem Balken zusätzlich numerisch erscheint
Viele Grüße Carsten
Viele Grüße Carsten
Motardplongeur
First dive with Sport 10.23 version yesterday: the speed bargraph is a little bit more interesting than the numerical value but:
* Too small: if you just look at, you don't see it; need to focus on and you lost on "efficiency"
* Too fast: speed is not enough filtered and just moving hand gives an orange light!
It has to be improved for a complete benefit. I guess it's an important work to do but it is maybe the only negative item of the Sport; so improve it would be perfect!
OSTC #12002 & #11150
Finewine
The display could possibly be bigger but apart from that it is a guide and it does exactly what it is supposed to do..........I think anyway!
Daniele Huber
ist es nicht möglich die nächsten The new OSTC Sport firmware auch auf Deutsch schreiben, denn nicht alle können leider Englisch.
Danke
Merci
Grazie
Daniele
Danke
Merci
Grazie
Daniele
eska
Würde ich mir auch wünschen.
bruene@hausarzt-lechenich.de
Hallo
Ich habe beim OSTC Sport die neuen Software installiert.
Jetzt bin ich auf den Malediven, kann aber meine Tauchgänge nicht auf mein Mac Book Pro auf Mac Dive laden.
Es kommt zwar im Mac Dice die Meldung "Beginning Import" und auf dem Sport die Meldung "Downloadmodus aktiv", aber dann die Meldung: "No new dives found" obwohl Tauchgänge dazugekommen sind und noch nicht übertragen worden sind.
Bitte um Hilfe
Albert
Bitte um Hilfe
Albert
Ach ja:
Wo und wie kann man den Safety Stop per PC konfigurieren.
Danke
Albert
Danke
Albert
glance
Subsurface 4.5.4 is due really soon, and in that version you can configure the safety stop parameters on your hwOS based DC's.
//Anton
//Anton
Continue here: read.php?6,16365
