The new OSTC Sport firmware 10.25 is now available for download: http://www.heinrichsweikamp.com/?id=479&version=de (German) or http://www.heinrichsweikamp.com/?id=479&version=en (English)
Changes since 10.20 (Changes since 10.23):
BUGFIX: Fix missing gas setup (From 10.24)
NEW: Safety Stop can be enabled/disabled from the menu
BUGFIX: Fix rare issue after battery change (OSTC sport did not start properly)
CHANGE: Show velocity from 3m/min or more (Ascend or descent)
NEW: Segmented speed graph in divemode (optional)
NEW: Variable speed (7-20m/min) depending on depth (optional)
NEW: Logbook marker can be set in dive mode menu
CHANGE: Logbook now shows end-of-dive date and time for dives made with firmware =10.22
CHANGE: button hold-down will increase values or move the cursor automatically (again)
BUGFIX: Bluetooth communications issues
NEW: Option to rotate the screen
OSTC Sport: New Firmware 10.25
Re: OSTC Sport: New Firmware 10.25
Hi all
Back in March there was the following quote about programming of the Safety-Stop Parameters:
"Subsurface 4.5.4 is due really soon, and in that version you can configure the safety stop parameters on your hwOS based DC's. "
I have sucessfully installes 10.25 for my sport and use Subsurface 4.5.4 for logging my dieves.
Even if I adjust the Safety-Stop Parameters (would like to start the 3 Min at 6m instead of 5m), these values will not be transferred or activated in the Sport.
Am I doing something wrong, or what exactla is the issue here?
Greetings from HongKong
TomtheRom
TomtheRom
Thom
Thom
There's a bug in 4.5.4, which is fixed in 4.5.5 which affects safety stop parameter. Upgrade to that one and it works.
//Anton
//Anton
Hi Anton
Yeah....tried that.
But 4.5.5 was not able to connect by bluetooth to my OSTC Sport.
After changing back to 4.5.4 the connection worked again (so nothig wrong with the computer).
Might you have a closer look in fixing both problem...please.?
Regards TomtheRom
Yeah....tried that.
Regards TomtheRom
Thom
Thom
Downloaded a test built and worked with that one - I assume that the nea 4.5.6 will do the same.
Thanks for working on that issue
Thom
Thom
Continue here: read.php?6,16767
