Brand new OSTC2, after upgrading to firmware 2.05 the left button stopped working and now i cant access any menu items or start Bluetooth again to downgrade.
Suggestions?
Button not working after firmware upgrade
Re: Button not working after firmware upgrade
Go to button menu and confirm a lower setting like 40% for both buttons.
Button is eventually on a higher setting (Like 100%) making it quite hard to press. Cool down the OSTC a bit and the button will be useable even in the higher settings and allows you to change this setting.
Since you emailed us in parallel (I was just told) with this we'll continue via mail here...
