Could the cave warning be also used for CCR?
It would be nice to see when you reach your bailout limit
Cave warning
Stephane
Re: Cave warning
The cave warning is meant to be used on cave CCR diving ...
Stéphane Acounis
Stéphane Acounis
Stephane
Re: Cave warning
With CF56 you set the SAC rate in l/min or bar/min, whatever you want.
With CF59 you program the alarm when you reach the gas consumption you want.
An example:
You take two S80 filled at 200bar as bailout. In case of bailout you want to keep half of the gas available in case anything goes really wrong.
CF56 is set at 20 l/min (yes, you are on bailout, you are a little bit stressed).
CF59 must be set to 2x200x11.1/2 or 2220.
When you start your dive, the computer will calculate the gas consumed according to the real dive profile and the SAC rate programmed if you were on OC. When you reach the limit you have set, the gas consumption goes red on the OSCT display.
That's it.
An example:
That's it.
Stéphane Acounis
Stéphane Acounis
