Stopwatch
Stopwatch
Hi Matthias,i know i have pestered you for a few weeks regarding the stopwatch function but as you say you have included it in the 1.40 stable,would it be possible to write me a beta version with the stopwatch displayed below the dive time in gauge mode? it would be really useful as a bottom timer,also could it be started and reset with one button? would be very grateful if you could implement this for me (i am sure others would find it useful aswell) thank you,regards,Simon.
Re: Stopwatch
I'll post it here soon. It can be reset with the ENTER button.
Re: Stopwatch
Thank you,really appreciate that,look forward to testing it.
Simon.
Simon.
Re: Stopwatch
Attached is a version that shows the stopwatch below the divetime (Only in Gauge mode).
Mattias
Mattias
Re: Stopwatch
Windows unzip says file corrupted or incomplete,also "file empty" nothing to extract.Have i done anything wrong?
Re: Stopwatch
Using the latest Internet Explorer?
Seems to be the cause....
Re: Stopwatch
heinrichsweikamp Wrote:
> Hello,
> regards,
> Mattias
Why only in "Gauge mode"?
/Fridholm
> Hello,
> regards,
> Mattias
/Fridholm
Re: Stopwatch
> Regards,
Hello,just downloaded version 8 and it makes no difference,just says "file empty" its a shame,i will keep trying.
> Regards,
Re: Stopwatch
We had this issue with the 1.40 recently. I always test any upload with two different computers and accounts. This file is not empty - I can download it without problems. Please send me your mail to info@heinrichsweikamp.com - I'll send you the file via email.
Re: Stopwatch
Hello again,just downloaded to the OSTC,the only issue is the stopwatch is in seconds only,can it be shown in minutes and seconds?
Re: Stopwatch
It can be displayed in mins:secs, of course.
How long are the times you are going to stop? Du you need hours, as well?
Re: Stopwatch
I am using it to keep track of bottom time (we dont include the descent) and to time decompression stops,so hours/mins/secs would be good.Is there a way of manually starting the stopwatch and then resetting it again? or does it have to start at the moment the dive has started?
Re: Stopwatch
Attached is a version that shows min:secs - just as like the divetime.
Re: Stopwatch
Thanks but i cant open that one,can you email me the attachment please?
Re: Stopwatch
You could try to instal firefox instead asking the file by email.
Re: Stopwatch
Sorry, that I write in german, but there are some terms I don't know in english:
Ich habe gerade eine Simulation im Gauge-Modus durchgeführt:
Wenn die Minuten der Stopuhr zweistellig werden, rutscht deren Anzeige um eine Stelle anch rechts, so dass die Einer-Stelle der Sekunden nicht mehr zu sehen sind.
Die durchschnittliche Tiefe sollte größer dargestellt werden, die Anzeige des aktuellen Gases braucht es im Gauge-Modus nicht.
OSTC Mk II #661
OSTC Mk II #661
Re: Stopwatch
Muss ich mir mal angucken, das wird zur nächsten Version gefixed!
Gruss,
Gruss,
