OSTC 2C firmware upgrade 1.81 -> 3.13
revo
Post by revo »
How to upgrade firmware version 1.81 to 3.13? I have downloaded the latest firmware version and also installed OSTC Companion v1.2. At first the companion didn't let me choose the *.hex file, but then I searched in the source code and found out that the file must be named *_firmware.hex. After renaming the file the Companion app reported "Error: Bad hex address". I'm using Mac OX.
Should I upgrade to v1.90 and then to 3.13? Where can I get the v1.90?
Re: OSTC 2C firmware upgrade 1.81 -> 3.13
Then you need to install the hwOS firmware: read.php?6,16526
Latest version is 2.07
Post by Bardass »
hwOS on OSTC 2C ?
As with most posts here in the forum, we get the same questions via mail, too (Which is really unnecessary btw.).
So I knew that the user has a "OSTC 2" (With Bluetooth and Wireless charging). And this device will not work with the 3.13 for the Mk.2, 2N and 2C :) (And luckily does not allow installation of this HEX file...)
