OSTC Tools for Windows - HWOS Config for Android
Post by Rob »
There is a new Version of OSTCTools availible.
New:
OSTC4 Support in HWOSConfig and some bugfixes.
With this program you can change all parameters of the following OSTC Computers: OSTC4, OSTC2, OSTC3, OSTC3+, OSTC cR and OSTC Sport.
Bugfixes in OSTCProfile when loading old OSTC2N/C profiles.
You can Download the OSTCTools free of charge at:
ostctools.angermayr.eu
or
www.angermayr.eu
Hallo zusammen,
Es gibt mal wieder eine neue Version der OSTCTools.
Der OSTC4 wird nun von HWOSConfig unterstützt und ein paar Bugs wurden gefixt.
OSTCProfile - Bugfixes bei der Anzeige von OSTC2N/C Profilen.
HWOS Config zum ändern aller Parameter der folgenden OSTC Tauchcomputer:
Die OSTCTools können wie immer hier kostenlos downgeloaded werden:
oder
www.angermayr.eu
tanomogi
Re: OSTC Tools - new Version
Post by tanomogi »
I can't set "ppO2 min"
Its fixed 0.15bar default and not adjustable value I think its very dangerous.
here is screenshot and technical reports
ppO2 min: 020 0x23 15 0 0 0 0x0F 0x00 0x00 0x00 0b00001111 0b00000000 0b00000000 0b00000000
[img]https://s9.postimg.org/k1qqtfkq7/20160810_180540.png[/img]
* "ppO2 max" for bottom/travel(no ppO2 max for Deco in this version) right?
BTW, thanx for development this cool tool!
Post by Rob »
ppo2min is 0.15 fixed by firmware.
Minvalue and Maxvalue are 0.15.
setting of ppo2max for deco is not supporyet by firmware yet.
regards
rob
sadsani@gmail.com
Post by sadsani@gmail.com »
does it come in mac os ?
Sulaiman OSTC3 OSTC4:73
Post by Rob »
No, sorry.
I don't own a Mac.
fk_muck1
Post by fk_muck1 »
Dear Rob
I have a new laptop with 4k monitor (resolution 3.840 x 2.160).
Realy like your tools, but the visibility of OSTCConfig on my monitor is cruel.
The windows are partly unreadable (pic 1) and unable to resize (pic 2).
The compatibility modes in Windows 10 didnt solve the problem.
Is there a chance for an update of your tools to make them more compatible with 4k monitors?
Post by Rob »
Hi Michael,
did you use any scaling with your screen?
Control Panel\Appearance and Personalization\Display
What happens if you set scaling to 100%.
Sorry i cannot reproduce this because i have no 4k monitor availible.
Something similar happend with my laptop but this was, as far as i know, solved.
I can try to do something, but you have to test it ;-)
Please contact me via mail. ostctools@angermayr.eu
Post by Rob »
New:
Latest functions for OSTC4 (Button sensitivity)
Fix: OSTC2/Plus Model detection.
Remove of the registration screen. No more searial neccessary.
There are Three setup files availible.
- ostctools-hwos-setup.exe
for The latest OSTCs (including all OSTC with HWOS firmware)
- ostctools-ostc2n-setup.exe
for the old OSTC 2N/C
- ostctools-setup.exe
a setup including all OSTC-Tools.
or
www.angermayr.eu
Hallo zusammen,
Neu:
OSTC4 Button Sensitivyty
Fix:
OSTC2/Plus Modell erkennung.
Ich habe den Registrierungsdialog entfernt. Eine Seriennummer ist nicht mehr nötig.
Es gibt nun drei Setups zum Download:
für die aktuellen OSTCs (inklusiver aller OSTCs mit HWOS Firmware)
für den alten OSTC 2N/C (mit den Custom Functions)
ein Setup für alle Modelle.
oder
www.angermayr.eu
tanomogi
Post by tanomogi »
Thanks a lot Rob!
fk_muck1
Post by fk_muck1 »
Thank you very much Rob and it works great with my 4K monitor!!!
Re: OSTC Tools for Windows - HWOS Config for Android
Post by Rob »
Hello forum,
i just released a new verson of HWOS Confog for Android. Now it supports OSTC4 Firmwareupdates.
you can find it here
But - i did a mistake - i tried to setup a BETA programm for this App in play store and this version should be in beta first. Somehow it finds its way to the release channel.
As there is no change in the HWOS routines and only OSTC4 is new implemented, i let the version as it is.
Please be aware that this is a Beta and feel free to send me your feedback, here in the forum or in a email.
If you find any Problems with this version togerther with HWOS firmware, please contact me an i will restore the old version.
To calm down, I have done about 30 firmware up and downgrades and all ran smoothly with my hardware.
Hallo forum,
ich habe gerade iene neue Version von HWOS Config für Android veröffentlicht. Die App unterstützt jetzt Firmwareupdates für den OSTC4.
Ihr könnt sie hier laden
Aber, mir ist ein Fehler unterlaufen. Ich habe versucht ein BETA Programm im PlayStore einzurichten, denn diese Version sollte zuerst als BETA getestet werden. Irgendwie hat diese Version ihren Weg in den Release Kanal gefunden.
Aber da keinerlei änderungen am ursprünglichen HWOS Code gemacht wurden und lediglicher der OSTC4 Support hinzugekommen ist, belasse ich es mal so.
Solltet ihr irgendwelche Probleme mit dieser Version und HWOS Firmware haben, sagt mir bitte bescheid, dann lade ich die alte Version wieder hoch.
Bitte denkt daran das das eine BETA ist, probiert es aus und schickt mir euer Feedback gerne hier im Forum oder per email.
Zur Beruhigung, ich habe ca 30 Firmware up und downgrades gemacht und alle liefen Problemlos mit meiner Hardware.
Post by Rob »
Hi folks,
yesterday i uploaded a new BETA Version of HWOS Config for Android.
Now it is a BETA and its not escaped to the release channel ;).
if you'd like to join the Betatest follow this Link
Than, you recieve new BETA versions of the Software automatically via google play.
Hallo zusammen,
gestern habe ich eine neue Beta Version von HWOS Config für Android auf den Playstore geladen.
Diesmal ist es wirklich eine Beta und nicht "entkommen" ;)
Wer die Betatest Version haben möchte klickt bitte auf diesen Link, du bekommst dann automatisch über google Play die Beta sobald sie hochgeladen ist.
Best regards/ viele Grüße
Post by Rob »
i just uploaded a new version of HWOSConfig for Android (1.1.10) to Google, it should be availibele in some hours.
The problem with android 9 (Pie) is now fixed, as far as i can see. (cross fingers)
The problem with the disappearing progressbar when touched should be fixed too.
When you have problems, please tell me.
German / Deutsch ------------------------------------------
Hallo zusammen,
ich habe gerade eine neue Version von HWOSConfig für Android (1.1.10) auf Google bereigestellt, Google üblich sollte sie in ein paar Stunden verfügbar sein.
Die Probleme mit Android 9 (Pie) sollten nun gefixt sein.
Das Problem mit dem verschwindenden Progressdialog auch.
Sollten noch Probleme auftauchen bitte meldet es mir gleich.
diveinstructor
Post by diveinstructor »
Hallo Rob,
mit meinem Samsung Galaxy 10 auf Android 10 kann beim OSTC4 die FW nicht updated werden. Wenn ich versuche die FW-Datei herunterzuladen hängt der Progress bei ca 70%. Die FW für den OSTC Plus wird problemlos heruntergeladen.
Es wäre nicht schlecht, wenn man auch die Beta-Versionen updaten könnte, z.B über eine manuelle Dateiauswahl.
VG
Oliver
Post by Rob »
i just uploaded a new version of HWOS Config for Android (1.2.01), according to google playstore it should be availible in some hours.
New:
Keeps only a certain number of firmwarefiles on the device. Please check the settings.
HWOS
firmware upgrade routines revised. According to some problems with fast devices.
OSTC4
The Problen thet Firmware and RTE needs to be separately upgraded should be solved.
Users with the latest Phones (fast ones), please give me feedback if there are problems or not.
Best reagrds
ich habe gerade eine neue Version von HWOS Config für Android (1.2.01) in den Playstore geladen, laut google ist diese in den nächsten Stunden verfügbar.
Neu:
Es werden nur noch eine festgelegte Anzahl an Firmwarefiles auf dem Gerät behalten. Bitte in den Einstellungen prüfen.
HWOS:
Die Firmware Upgrade Routinen wurden überarbeitet, das es Probleme mit sehr schnellen Smartphones gab.
OSTC4:
Das Problem das man für Firmware und RTE den Upgrade zweimal durchführen musste sollte nun bereinigt sein.
Nutzer die ein schnelles, aktuelles Smartphone haben, bitt gebt mir kurz Feedback ob es Probleme gibt oder nicht.
Post by Rob »
a new version of HWOS Config for Android (1.2.02) is availible in Google playstore.
Bugfix: Heartbeat implemented, this prevents the automatic disconnect of an existing bluetooth connection from the OSTC.
Bugfix: Umlauts and special characters are allowed with the personalization (custom text).
This is for HWOS and OSTC4.
Best reagrds
eine neue Version von HWOS Config für Android (1.2.02) ist im Google Playstore verfügbar.
Bugfix: Heartbeat implementiert, dieser verhindert ein automatisches schließen der Bluetooth Verbindung seitens des OSTCs.
Bugfix: Umlaute und Sonderzeichen können zur personalisierung (custom text) des OSTC verwendet werden.
Gilt für HWOS und OSTC4.
Post by Rob »
I have just uploaded a new version of HWOS Config for Android (1.3.00) to the Playstore.
Support for OSTC2 with sensor interface, called "Tech O2" for simplicity.
Displayed firmware types configurable in the settings.
And now for the biggest change.
Unfortunately, I had to give up the /HWOSConfig folder where firmware files were previously stored.
According to Google guidelines, they are now stored under /Android/data/eu.angermayr.hwosconfig/files.
Depending on the firmware type (Sport, Tech, Tech with O2 interface, OSTC 4) in a separate subdirectory.
The folder is located on the device or on the external SD card, depending on what is set in the smartphone.
The advantage of this folder is that it is deleted together with its contents when the app is uninstalled.
Disadvantage of this folder; it is deleted along with its contents when the App is uninstalled.
The directories are:
/Android/data/eu.angermayr.hwosconfig/files/fw_sport
/Android/data/eu.angermayr.hwosconfig/files/fw_tech
/android/data/eu.angermayr.hwosconfig/files/fw_techo2
/android/data/eu.angermayr.hwosconfig/files/fw_ostc4
If you have firmware files in the HWOSConfig directory that you want to continue using,
please copy them manually into the appropriate directory.
Then please delete the HWOSConfig directory on your phone manually, the app (unfortunately) no longer has access to it.
ich habe gerade eine neue Version von HWOS Config für Android (1.3.00) in den Playstore hochgeladen.
Unterstützung für OSTC2 mit Sensor Schnittstelle, der Einfachheit genannt "Tech O2".
Angezeigte Firmwaretypen in den Einstellungen konfigurierbar.
Und nun zur größten Änderung.
Leider musste ich den Ordner /HWOSConfig in dem bisher die Firmware Dateien gespeichert wurden aufgeben.
Nach den Google Richtlinien werden diese jetzt unter /Android/data/eu.angermayr.hwosconfig/files gespeichert.
Je nach Firmwaretyp (Sport, Tech, Tech mit O2 Schnittstelle, OSTC 4) in einem eigenen Unterverzeichnis.
Der Ordner befindet sich auf dem Device oder auf der externen SD Karte, je nachdem was im Smartphone eingestellt ist.
Vorteil dieses Ordners; er wird bei Deinstallation der App mitsamt dem Inhalt gelöscht.
Nachteil dieses Ordners; er wird bei Deinstallation der App mitsamt dem Inhalt gelöscht.
Die Verzeichnisse sind:
/Android/data/eu.angermayr.hwosconfig/files/fw_techo2
/Android/data/eu.angermayr.hwosconfig/files/fw_ostc4
Solltet ihr im HWOSConfig Verzeichnis firmware Dateien haben die ihr weiter nutzen wollt,
bitte manuell in das entsprechende Verzeichnis kopieren.
Das HWOSConfig Verzeichnis auf eurem Phone dann bitte manuell löschen, die App hat (leider) keinen Zugriff mehr darauf.
Post by Rob »
i just uploaded a new version of HWOS Config for Android (1.3.01) to the playstore.
The only change is a bugfix for Xiaomi (and other Chinese smartphones) with Android 12,
these have a Bluetooth interface that does not meet the specifications.
Maybe someone with a Xiaomi Android 12 smartphone, I don't own one, can test if it connects to the OSTC and let me know.
Best reagrds
ich habe gerade eine neue Version von HWOS Config für Android (1.3.01) in den Playstore geladen.
Die einzige Änderung ist ein Bugfix für Xiaomi (and andere chinesische Smartphones) mit Android 12,
diese haben einen nicht den Spezifikationen entsprechende Bluetooth Schnittstelle.
Vielleicht kann jemand mit einem Xiaomi Android 12 Smartphone, ich selbst besitze keines, einmal testen ob es sich mit dem OSTC verbindet und mir bescheid sagen.
mikeller
Post by mikeller »
Hi Rob.
Thank you for your efforts with HWOS Config.
I just tested HWOS Config 1.3.01 on a Xiaomi Redmi Note 7 running MIUI Global 12.5.3, and connecting to an OSTC4 is working fine.
Michael Keller
Walde
Post by Walde »
Writing firmware stops at 6%.
When I start HWOS Config the bluetooth is connected ok, clock is updated, when firmware update is started it stops at 6%.
OSTC4 goes to home screen and when I check the bluetooth from the OSTC4 it's off. Does not help if I put it back on.
Uninstalled and installed HWOS Config, didn't help. Phone is Galaxy S20 FE with Android 13.
OSTC4 has RTE 2.9 OS 1.6.0.
Post by Rob »
Walde wrote: 13 Apr 2023, 16:34 When I start HWOS Config the bluetooth is connected ok, clock is updated, when firmware update is started it stops at 6%.
Hi Walde,
please contact Matthias,
i have the same here with one OSTC4. The Problem is that the OSTC switches off bluetooth during the update,
for any reason.
A second OSTC4 did the update (and downgrade now for the 10th time without any problems).
I have the same problem.
Post by Rob »
@swissdiving
@walde
Can you please install the attaced Version of hwosconfig and try the update again?
HWOSConfig-release-1302.zip
(1.8 MiB) Downloaded 13642 times
I assume its for Windows.
Post by Rob »
It's for Android. :-)
