Diving Log downloader update
divinglog
I'll post here in future updates of the OSTC downloader for Diving Log with changelog.
To download click here: ImportOSTC.zip
You can either use it as standalone tool or extract the zipfile into the Diving Log program folder to start it from Diving Log.
[Version 1.0.0.8 - 2008/01/17]
- new button in simulator window to reset deco data
- new temperature calibration value in OSTC settings grid
- small bug fixes
Edit to add: make sure that you're running the latest firmware version on your OSTC, otherwise some functions may not work.
- small bug fixes
Lieven Bogaert
Re: Diving Log downloader update (english)
I'm using Vista Ultimate x64 and the tool gives me the following error:
The 'Microsoft.Jet.OLEDB.4.0' provider is not registered on the local machine.
I think in the compiler for the tool, you have to explicitly force your app to use 32 bit by changing the target cpu to x86.
Hello Lieven,
Post this report also in the Divinglog-Phorum: http://www.divinglog.de/phpbb/
I think Sven will check this forum more often.
divinglog
Hello Lieven,
Please write me an email to info (at) divinglog.de so we can try to fix this problem.
Sven
Sven
divinglog
New version of the OSTC downloader for Diving Log 4.0: ImportOSTC.zip
[Version 1.1.0.0 - 2008/03/05]
- support of the new profile format of firmware version 1.08 (stable)
- new firmware check dialog
- small bug fixes
With this update the new profile format is supported which has a lot of enhancements. This version will read both, the old and the new format from the internal OSTC logbook.
- small bug fixes
divinglog
[Version 1.1.0.1 - 2008/03/14]
- new option to set first gas and decotype of OSTC
- improved firmware check dialog
- improved download routine
- bugfix with x64 Windows
divinglog
[Version 1.1.0.2 - 2008/04/07]
- support of new firmware 1.10 beta features
- new setting decotype constant ppO2
- new setting gas active Yes/No
- new setting gas change depth
- new settings for ppO2 setup
[img]http://www.divinglog.de/pics/OSTCSettings.png[/img]
divinglog
[Version 1.1.0.3 - 2008/05/16]
- support of firmware 1.12 beta features
- new category "History" with detailed OSTC info
Extract the zipfile into your Diving Log program folder and replace the old files.
[img]http://www.divinglog.de/pics/OSTCSettings2.png[/img]
divinglog
[Version 1.1.0.4 - 2008/06/30]
- support of firmware 1.15 features
You can display now a custom text at the surface screen of the OSTC.
[img]http://www.divinglog.de/pics/OSTCSettings3.png[/img]
divinglog
Es gibt ein Update f?r den OSTC Downloader f?r Diving Log 4.0: ImportOSTC.zip
[Version 1.1.0.5 - 29.07.2008]
- Support der Firmware 1.17 Funktionen
Die Zipdatei nach dem Download in den Diving Log Programmordner entpacken.
[Version 1.1.0.5 - 2008/07/29]
- support of firmware 1.17 features
divinglog
[Version 1.1.0.7 - 19.09.2008]
- Support der Firmware 1.19 Beta Funktionen
- Anzeige der Anzahl der ge?nderten CF in eckigen Klammern (siehe Screenshot unterhalb)
Die Custom Functions II (CF32 und CF33) k?nnen derzeit noch nicht von Diving Log aus ge?ndert werden, das folgt aber in K?rze mit einem weiteren Update. Diese Version sollte nur verwendet werden, wer die Firmware 1.19 Beta oder h?her verwendet.
[Version 1.1.0.7 - 2008/09/19]
- support of firmware 1.19 Beta features
- display number of changed CF in square brackets (see screenshot below)
The Custom Functions II (CF32 and CF33) cannot be edited in Diving Log at the moment, this will be available in another update, soon. You should only use this version if you have firmware 1.19 beta or higher installed.
[img]http://www.divinglog.de/pics/OSTCSettings4.jpg[/img]
