The 1.2.0 is available for download from our new homepage: www.heinrichsweikamp.com
CHG: duration of dive is now total time minus all time close to surface
NEW: CCR with sensors has 10 minutes timeout instead of 2 minutes like in other modes
FIX: button reset on start-up after updating to firmware 1.1.8
NEW: added ascent and descent rate in (small) numbers
CHG: failsafe if computer is turned on during flight (880 mbar limit instead of 700 mbar)
NEW: most center custom views can be turned on and off during dive (new menu in dive mode)
FIX: temperature graph in logbook
NEW: button sensitivity overdrive with 105% and 110% now available
FIX: helium desaturion time in logbook entry
kind regards,
Christian
						New OSTC4 firmware 1.2.0 available
				CrissCross
Re: New OSTC4 firmware 1.2.0 available
Hi Christian,
at first view the firmware (update) works fine, thanks!
Only one remark concerning the “center custom view”: For the german firmware version / language there is a missing “Ü” for “Übersicht”, see attachment (2016-12-16_CCV.jpg).
Best regards,
Christian
Best regards,
Christian
				gorcio
Quick question - can those custom center views be configured off before the dive ?  I do not want to play with menus under water - just want to set them off for good
gorcio
gorcio
Kind regards,
Gorcio, OSTC MK2 828
				ebertalex
Hi Christian,
I uploaded the OSTC companion sw from the alternative site you gave me. Thanks!
I then uploaded the new firmware version 1.2.0 to the OSTC using the file "OSTC4update_161214_FW_1_2_0__RTE_0_96.bin". That worked well except for RTE96. The computer now flashes "please update RTE" and I can see in the SYS menue that it still has RTE 0.93 (and OS1.2.0).
I rebootet firmware as well as RTE to no avail.
Please advise.
Thanks!
Please advise.
Thanks!
OSTC4 #198
OSTC4 #198
				sadsani@gmail.com
please do the following .. let the OSTC4 sleep after  few minutes
repeat the firmware update
it will pick-up were it was stoped and will flush the RTE
try it
try it
Sulaiman  OSTC3 OSTC4:73
> OS1.2.0).
Hi Alex,
Just restart the update process and/or reboot the unit.
> OS1.2.0).
Hi Alex,
				ebertalex
I did exactly that but it did not help. The odd thing is that the ostc companion afterwards confirmed that RTE v0.96.0 was indeed uploaded to the dive computer. After rebooting firmware and RTE the computer still lists "RTE 0.93 OS1.2.0" and flashes "please update RTE".
Shall I send you the screen shots? if so, to what email address?
OSTC4 #198
OSTC4 #198
				tanomogi
Yes.. it still suffering when it updates.
Check below it first.(It always reset/reboot RTE/Firmware/Settings)
seel the bottom of the messages "SOLVED"
RTE(Part-3) update methods
				ebertalex
all right, that worked well.
Thank you!
							Thank you!
OSTC4 #198
OSTC4 #198
