Hi all,
don't knwo if it could be a bug but I have bluetooth set to on and do a dive simulation with simulator. When I quit the simulator, then bluetooth is automatically set to off. Tried this several times and it happened every time.
Normal or could it be a bug?
Christoph
						Bluetooth goes automatically inactive after quit simulator, bug?
				chrisrms
Re: Bluetooth goes automatically inactive after quit simulator, bug?
Which firmware version do you have installed on your ostc?
				chrisrms
It's the OS 1.3.0 and RTE 1.1
It's a very new computer which came like this from Heinrichs Weikamp. I have it for about 10 days now.
hmm, bluetooth should be enabled as standard with V1.3.0 (when not sleeping).
at least thats what I understand.
question: why do you need a bluetooth connection for the SIM?
When you say set to off, you mean the SYS menu of the OSTC?
				chrisrms
I try to explain again
I have the checkmark set in SYS > Bluetooth
Then I go to SIM and do a dive simulation with the simulator
After the simulation has finished, or during the simulation I quit it (I mean the simulation) then there is no checkmark anymore in SYS > Bluetooth.
It seems that Bluetooth gets automatically turned off. If you have the same OS 1.3.0 you should normally experience the same as me, or my OSTC 4 could have a problem.
Christoph
Christoph
bluetooth is turned off in dive mode. As the simulator is like a dive it disables the bluetooth. The same is true after a dive.
The automatic enable bluetooth is meant to be a help to use bluetooth straight after turning on the unit without further activity.
Bluetooth can be easily actived again directly after a dive in the menu.
Christian
Christian
(tu)
thx christian
							thx christian
				chrisrms
Ok, understood, so it's normal! It is clear now
Thanks for explanation.
Christoph
Christoph
