I have an OSTC 3 and I can not connect to bluetooth. Is there an OSTC 3 model not compatible with Bluetooth if yes what to do?
Can be changed against the non-compatible model
Thank you for your answers
charles
OSTC 3
Re: OSTC 3
Hi Charles,
As far as I know, there is only two types of OSTC 3 : the former one with a USB connection (on the back of the unit), and the 3+ whith Bluetooth but no USB.
The Bluetooth ID of my OSTC 3+ is BM+SR 3B74 (3B74 being tha last four digit of its MAC address). Do you see something similar when you run a Bluetooth scan ?
Regards.
Regards.
charles
Re: OSTC 3
ok mine having a USB socket in the back it is not bluetooth. I thought this had to be with the software in the last update being 2.15.
I also saw that the OSTC 3 was no longer in the catalog HW it means that there will be no update?
Regards.
Regards.
Re: OSTC 3
The last hwOS beta (2.23) is still fully compatibe with the OSTC 3/3+, so I guess they will continue at least some time...
I installed it on my own OSTC 3+ and its works fine, but you can wait for the next stable version (2.24 ?)
