if you mean the display color options (Settings -> Display Settings -> Colour Scheme) - they have been there since ages...
Yes, the content of the custom views has been rearranged a little bit, reducing multiple displaying of the same parameter and grouping some parameters that have cross-relations into the same view. That created some space for the surface pressure.
My OSTCs run quite smooth regarding button press to cursor reaction in surface modes and menues. But yes, to stabilise the display animations (blinking et. al.) in dive mode, the processing sequence has been changed so that Display Animation now takes preceedance over menu operation. That introduces a little bit of lag.
The Air Integration functions should not be visible on none-TR models. Maybe the hardware detection routine is not perfect yet. Which type of OSTC are you using? Anyhow, they can be deactivated via Settings -> Pressure Display -> Mode = off. When mode is set to off, all TR-specific code is skipped. Well, this menu entry schould also only be visible on TR models...
