MOD maximum of 99m
jlm
MOD maximum of 99m
Post by jlm »
Let say I want to use a bailout OC gas 8/92 and max bottom po2 of 1.2 bar. This gas has a MOD of 140m, but hwOS uses a maximum MOD of 99m. Is there a reason to limit this to 99m? There seems to be room in the UI for 1 extra digit.
--jan
Re: MOD maximum of 99m
Hi Jan,
no, there is not a specific reason. It seems to be a left-over from the times were the gas set as first was supposed to be the deepest gas as it had a hard-coded unlimited depth. Will change that in V3.00...
