OSTC2 Custom Functions documentation
OSTC V2.59beta - Documentation Fonctions Personnalisables
Ci-jointe, la version française de la description des paramètres de configuration pour la version 2.59beta de l'OSTC.
Bonne lecture,
Jean-Philippe
Bonne lecture,
Jean-Philippe
OSTC 2N #2755
OSTC Custom Functions documentation V2.70 DE
hier die Custom Functions Dokumentation für das RELEASE 2.70 der OSTC Firmware.
ACHTUNG! - ich habe versehentlich eine falsche Version der Datei hochgeladen die viele Fehler enthielt.
Ist nun korrigiert! 14:45 Uhr
Grüße
Grüße
Home: http://www.angermayr.eu
email: ostctools@angermayr.eu
OSTC V2.70 - Documentation Fonctions Personnalisables
Ci-jointe, la version française de la description des paramètres de configuration pour la version 2.70 de l'OSTC.
Bonne lecture,
Jean-Philippe
Bonne lecture,
Jean-Philippe
OSTC 2N #2755
OSTC Custom Functions documentation V250 EN
here the Custom Functions documentation for the latest RELEASE v2.70 in english.
Please report errors, mistakes or unclear descriptions. Thanks.
regards
regards
Re: OSTC Custom Functions documentation V250 EN
Thank's Rob
regards
regards
After much procrastination I have produced an A5 format PDF for the Custom Functions for firmware version 2.70 in English. If you print it out you'll be able to add your own 'current' settings for each CF. The text and values are as displayed by my OSTC 2N.
Happy diving,
Laurie (OSTC2 #11454)
HW, the source is in a *.ods file. I can post this if requested.
Happy diving,
If you make it in A6 format and add some space on the long side for 3 holes, then it would fit into the famous IQ-Logbooks... (tu)
Laurie_the_Knot Wrote:
> Hi,
> by my OSTC 2N.
Laurie,
I really like that smaller version to keep track of my settings. Makes it easier to keep track of.
> Hi,
> by my OSTC 2N.
Laurie,
Re: OSTC2 Custom Functions documentation
Hi all,
The OSTC2 Custom Functions documentation is valid for the 2.90 (Nothing new between 2.70 and 2.90).
Die Beschreibung für die Custom Functions ist auch für die 2.90 gültig (Keine Neuerungen seit der 2.70).
Hello
Lovely job !
Would you post the ods file please.
Xis
> this if requested.
Lovely job !
Xis
> this if requested.
OSTC Custom Functions Dokumentation V2.94 DE BETA
hier die Custom Functions Dokumentation für die BETA 2.94 der OSTC Firmware.
Bitte meldet mir Fehler oder unklare Beschreibungen.
Danke.
Grüße
Danke.
Grüße
OSTC Custom Functions dovumentation V2.94 EN BETA
here the Custom Functions documentation for the latest BETA v2.94 in english.
Thanks.
regards
Thanks.
regards
As requested, attached is my version of the OSTC2 custom functions documentation in ODS format. I have updated it for firmware version 2.94 changes.
If you have any suggestions for enhancement or better descriptions of the meanings/use of any CF please post here.
Happy diving,
Hello .. I just bought my first OSTC 2n .. I read in the manual that here I could find a list custom functions, I try to download the file but the download does not start: can someone help me? you know if it also exists in Italian list ?? thank you
HI, Is the V294 the last version for 2C
Thank you.
Thank you.
> Thank you.
No, it's 2.94beta: https://www.angermayr.eu/images/downloa ... ons_EN.pdf
> Thank you.
Hi everybody,
Thanks for this great work.
Now, the latest version is 3.15.
Is there some differences in custom parameters since 2.94 version ?
I don't find the attached files, may you explain how to download it ?
Thanks for all,
Sandrine
OSTC 2N Year 2011
Thanks for all,
Sandrine
OSTC 2N Year 2011
Click on the link from my post just above your post.svac wrote: 08 Aug 2021, 10:28 Is there some differences in custom parameters since 2.94 version ?
The link still is valid and there were no changes in the CF in the 3.15 release.
Thanks for your answer.
I didn't find the custom parameter to write my name on the last line in surface mode as indicated in the manual.
Do you not if it exist ? And if yes, it's number ?
I've just installed the 3.15 firmware on my OSTC 2N number 2762.
As far as I can remember you have to do that with an App. I can't remember that there is a CF for the custom text. Its much easier with an app anyway.
