I can connect with OSTC Companion (Mac) but then, impossible to click on "Upgrade Firmware", button is grey. Please help
Kind regards,
Filip
Upgrade 1.3.0 to 1.4.8
Re: Upgrade 1.3.0 to 1.4.8
Click on "Upgrade Firmware..." without prior "Connect".
Hi Matthias, after upgrade, I have screens in attached files. First screen with all values set to zero, after a while there was screen with text "Shutting down". But now, the screen "Shutting down" is there allready for 10 minutes and nothing happens, screen stays on... What to do now ?
Kind regards,
Filip
[img]https://forum.heinrichsweikamp.com/file ... G_6954.jpg[/img]
Kind regards,
Filip
Restart the update (Wakeup the unit with the left button) to finish the installation of the Part3 (RTE).
OK, part3 finished (RTE). Resulting screen shows "cold start" in red and battery empty (red). After restart computer, "cold strat is gone" but battery still empty. Battery was fully charged before upgrade (20 minutes of so ago). How to solve ?
Kind regards,
Filip
Kind regards,
Filip
All looks normal.
Menu -> SYS2 -> Reset Menu -> Maintenance -> Restore Battery
And if this is not available: Recharge.
The OSTC4 will know it's battery state again after being recharged.
All looks normal.
All good now ! Thanks again for the magnificent support
Kind regards,
Filip
Kind regards,
Filip
