looking for French Translations
this one is to all fellow OSTC users that like to help us improve the French language version. Below you'll see an excerpt from the language file containing all the words for which we don't have the matching French word, or are not sure if the word we have is correct. In most cases the words have restrictions on their length (number of characters). Sometimes the max. length is explicitly stated, else the new word should be about the same length as the given one (shorter is no problem). If you have any ideas, please simply reply with pairs of the word identifier (it's the tXXXX after 'TCODE') and the French word, one pair per line.
Thanks a lot,
; Divemode Menu
TCODE tDivemenu_Avg_Mkr, "Avg/Marker" ; Reset Avg, Set Marker (and Turn Dive)
; Main menu
TCODE tTrSettings, "Pressure Display" ; Pressure Display
TCODE tTrMaxDeltaP, "max deltaP: " ; independent double max diffenerce
; Dive Settings
TCODE tAscentSpeed, "Ascent Speed : " ; Ascent Speed
TCODE tGasChangeTime, "Gas Change :+" ; additional Gas Change Time
TCODE tExtendedStops, "before 1.Stop: " ; gas switches before 1st stop
TCODE tStoreApnoeDive, "Store Apnoe : " ; Store Apnoe Dives
TCODE tDiveaGF_active, "using aGF" ; using aGF
TCODE tTankUsablePress, "Pression Ascent" ; Tank Pressure Budget for Ascent (turn pressure) (max 19 chars)
TCODE tCopyDilToOC, "Copy Dil.-> OC" ; copy diluent settings to OC gas
TCODE tTankPairing, "Config. Transmitter" ; select Transmitter
TCODE tTrModeOff, "off" ; off
TCODE tTrModeOn, "on" ; on
TCODE tTrModeIndDouble, "indep.Double" ; independent double
TCODE tTrPresNone, "none" ; none (big enum group follows)
TCODE tTrPresFirstGas, "First Gas" ; first Gas
TCODE tTrPresActiveGas, "active Gas" ; active Gas
TCODE tTrPresFirstDil, "First Dil" ; first Dil
TCODE tTrPresActiveDil, "active Dil" ; active Dil
; Display Settings
TCODE tLayout, "Layout :" ; Layout
TCODE tLayoutNormal, "normal" ; normal
TCODE tLayoutBig, "big" ; big
; Setup Menu
; 111 111 111 111 111
; 5 rows by 12 chars each: 123456789012123456789012123456789012123456789012123456789012
TCODE tDefName, " Read the Manual, know& understandthe inherentLimitations!"
; Decoplanner submenu
TCODE tCalcSurfInter, "Surface Interval" ; Surface Interval
TCODE tCalcBotSeg, "Bottom Segment" ; Bottom Segment
TCODE tCalcBailout, "Switch to Bailout" ; Switch to Bailout
TCODE tCalcAscent, "Ascent" ; Ascent
TCODE tNDLleft, "left" ; time left within NDL
; Divemode screen
TCODE tTissuePresSat, "Pres+Sat" ; 0 pressure and saturation | ENUM group
TCODE tTissueN2He, "N2+He" ; 1 N2 + He pressure |
TCODE tTime, "Time" ; Time
TCODE tSurface, "Surface" ; Surface (max 12 chars)
TCODE tGFInfo, "Saturation" ; Saturation
TCODE tGasNeedsAscent, "Besoins Gaz Ascent" ; Gas Needs Ascent
TCODE tgaschange, "Change?" ; better gas found
TCODE tNeed, "Need " ; gas need (5 chars)
TCODE tTransmitter, "P.Transm." ; pressure transmitter
TCODE tswap, "Swap Tank" ; swap tank (max. 9 chars)
TCODE tDiveTurned, "Dv.turned" ; dive is turned (max. 9 char)
; Reset menu
TCODE tResetSettings, "RaZ Settings" ; Reset Settings
; Logbook Offset Menu
TCODE tLogOffsetValue, "Offset : " ; Offset
TCODE tLogOffStepSize, "Step Size: " ; Step Size
Re: looking for French Translations
Hi Ralph,
I try to do these transations quickly. Of course Claude's help is welcome !
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
ClaudeDive
Post by ClaudeDive »
I started to do the translation, I send it as soon as possible in 1 to 2 days ...
Ralph & Didier, I think it would be easier by email than on the forum, do you have an email address to give me, here or on Messenger
Mail > claude.dive@gmail.com or @yahoo.fr
Cheers ;)
Great - no hurry!
You can also email to HW, it'll reach me.
ClaudeDive
OK Ralph (tu)
Kind Regards
Cheers ;)
ClaudeDive
- After the Beta version downloaded in French translation adjustments will may be necessary ...
- I put my text in blue and text bold the proposal which seems to me the best ...
- Ralph, it's appropriate that you find the best translation and abbreviation in the proposals below, to answer the place available on the screen, of course if you hesitate between two choices or combinations, I can help you find the best choice.
. Menu Divemode ...
TRANSLATION IN PROGRESS TO FOLLOW ... see Post below.
Cheers ;)
Ralph, it would be usefull to have the max number of characters for each field.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Alright, looked up max. number of chars for each text, see attached file.
:-) Ralph
Thanks Ralph, we go ahead with Claude.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
ClaudeDive
V3.03 FRENCH TRANSLATION FOR RALPH
Hi Ralph & Matthias,
- I put my text in blue and text bold or underlined the proposal which seems to me the best
- When it appears the signs u"..."u on the Word file, it corresponds to the function underlined on the Forum HW,
- The proposals of Didier A. Defay will be noted in red on this post,
; Divemode Menu ; "Menu Plongée"
TCODE tDivemenu_Avg_Mkr, "Avg / Marker"; Réinitialiser Avg, Définir Marqueur (et Turn Dive) (10 chars)
- ??? > I don't understand the subject, it would be necessary, if possible, to see a screen and the context ...
- Proposals > "Repère Moyen." or "Initialiser Repère" or "Initialiser Moyen." or "Mi-Plongée"
or "Repère Mi-Plongée" or "Index Mi-Plongée"[/u]
; Main menu ; "Menu Principal"
TCODE tTrSettings, "Pressure Display"; (16 chars, maybe 17)
"Affichage de la pression"; "Affich. Pression" or "Affich.Pression";
TCODE tTrMaxDeltaP, "max deltaP: "; independent double max diffenerce; (12 chars incl ":")
"Max Delta P:" or "Max Delta P:" or "Max Delta Press.:"
; Dive Settings; "Data Plongée" or "Régl. Plongée" or "Réglages Plongée"
Or "Paramètres de Plongée" or "Paramètres Plongée" or "Paramètres Plgée" or "Paramètre Plgée"
TCODE tAscentSpeed, "Ascent Speed : "; (15 chars incl ":")
"Vitesse de Remontée:"; or "Vitesse Remontée:" or "Vitesse de Rtée:" or "Vitesse Rtée :"
or "Vites.Remontée:" or "Data Remontée :" or "Data Rtée"
TCODE tGasChangeTime, "Gas Change :+"; additional Gas Change Time (17 chars incl ":+")
"Temps Change Gaz:+" or "Tps Change Gaz :+" or "Tps Chge Gaz:+" or "Changement Gaz:+"
TCODE tExtendedStops, "before 1.Stop:"; gas switches before 1st stop (17 chars incl ":")
"Inter 1er Stop:" or "Inter avant 1er Stop:" or "Avant 1er Stop:" or "Gaz AV 1er Stop :" or "Gaz >1er Stop:"
or "Inter Gaz > 1er stop" or "InterGaz>1erStop:"
or "Avant 1er Stop :"
TCODE tStoreApnoeDive, "Store Apnoe:"; Store Apnoe Dives (17 chars incl ":") > "Carnet Apnée :"
TCODE tDiveaGF_active, "using aGF" ; (9 chars) > "aGF Actif"
TCODE tTankUsablePress, "Pression Ascent" ; Tank Pressure Budget for Ascent (turn pressure) (19 chars)
"Besoin Press DTR" or"Besoin Press. Rtée" or "Besoin Press. Rem."
TCODE tCopyDilToOC, "Copy Dil.-> OC" ; copy diluent settings to OC gas; (19 chars) > "Copie Diluant -> OC";
TCODE tTankPairing, "Config. Transmitter"; select Transmitter (19 chars)
"Appair.Transmetteur" or "Pair.Transmetteur" or "Pairage Transmetteur"
or "Appair.Sonde" or " Appairage Sonde" or "Pairage Sonde" or "Pair Sonde"
TCODE tTrModeOff, "off"; (12 chars) > "Off"
TCODE tTrModeOn, "on"; (12 chars) > "On"
TCODE tTrModeIndDouble, "indep.Double"; independent double (12 chars) ??? > I don't understand the subject …
" Indep.double" ???
TCODE indépendant tTrPresNone, "none"; none (big enum group follows) (9 chars)
"No Press." or "Press.Nulle"
TCODE tTrPresFirstGas, [s]"First Gas"[/s]; (9 chars) > [s]"Premier" or "First Gas"[/s]
It's better "Bottom Gas" or "Bottom"; "Gaz Fond"
Note: Ralph, in an old discussion with Matthias, I had reported that the appointment of "First Gas" was unclear, it's confusing for a Tek diver, "First Gas" is the name used only by hwOS to talk about the "Bottom Gas", more the name of "First Gas" is false with diving Trimix Hypoxic since we use a "Travel Gas" on the descent for the first meters and so the "First Gas" is not the first but the second gas used on bottom ...
In diving Normoxique Trimix is used first the "Bottom Gas"
In Tek Dive the naming of gases in international language that all Tek divers understand without ambiguity:
- "Travel Gas" > French > "Gaz Voyage" or "Gaz Transit"
- "Bottom Gas" > French > "Gaz Fond"
- "Deco Gas" > French > "Gaz Déco"
It's for these reasons that I ask you, if possible, to replace "First Gas" by "Bottom Gas" at least in French "Gaz Fond".
Also, it would be nice to have a letter in front of the gas when they are active as the same idea as the asterisk currently
T: Travel Gas > French > V: Gaz Voyage or T: Gaz Transit
B: Bottom Gas > French > F: Gaz Fond
D: Deco Gas > French > D: Gaz Déco
-: Disabled Gas > French > -: Gaz Inactif
This will allow a quick and sure control of the gas programming,
The names of the gases in English (Travel, Bottom, Deco) can be possibly preserved in French because understand by Tek french divers
TCODE tTrPresActiveGas, "active Gas"; (9 chars) > "gaz actif" ;
TCODE tTrPresFirstDil, "First Dil"; (9 chars) > "Premier D" or "First Dil" or "1er Dil."
TCODE tTrPresActiveDil, "active Dil"; (9 chars) > "Dil.actif"
; Display Settings ; "Data Affichage" or "Paramètres Affichage" or "Paramètres Affich" or "Paramètres Affi"
TCODE tLayout, "Layout:"; (10 chars incl ":") > "Affichage" or "Affich."
TCODE tLayoutNormal, "normal"; (6 chars, tLayout + tLayoutNormal max 19 chars)
"Affich.Normal" or "Affichage Normal"
TCODE tLayoutBig normal , "big"; (6 chars, tLayout + tLayoutBig max 19 chars)
"Affich.Gros" or "Affichage Gros" or "Affichage Plus" or "Affichage Large"
; Setup Menu ; "Menu Réglages"
Lire Manuel
Connaitre et
Comprendre
Les limites
Essentielles
or
Manuel OSTC
Connaitre et
Comprendre
Les limites
Essentielles
or
Lire la doc.
Connaitre et
Comprendre
Les limites
de l'OSTC !
; Decoplanner submenu, "Decoplanner" or "Planif. Déco"
TCODE tCalcSurfInter, "Surface Interval" ; (19 chars) > "Intervalle Surface"
TCODE tCalcBotSeg, "Bottom Segment" ; (19 chars) > ???? > "Segment Fond" or "Segment Bas"
TCODE tCalcBailout, "Switch to Bailout" ; (19 chars) > "Mode Sauvetage" or "Mode Bailout" or "Mode B/O"
or "Plan de Secours" or "Plan Secours"
TCODE tCalcAscent, "Ascent" ; (12 chars) > "Remontée"
TCODE tNDLleft, "left" ; time left within NDL ; (6 chars) > "NDL" or "Temps NDL" or "Tps NDL"
; Divemode screen, "Mode Plongée" or Affich. Plongée" or "Affich.Mode Plongée" or Affich.Mode Plgée"
TCODE tTissuePresSat, "Pres+Sat" ; 0 pressure and saturation | ENUM group ; (9 chars, max 19 including tTissueGraphics)
"Press+Sat" or "Pression+Saturation"
TCODE tTissueN2He, "N2+He" ; 1 N2 + He pressure | ; (9 chars, max 19 including tTissueGraphics)
"N2+He" or "Pression N2 + He"
TCODE tTime, "Time of Day"; current (wall clock) Time (12 chars) > "Heure"
TCODE tSurface, "Surface" ; Surface (12 chars) > "Surface"
TCODE tGFInfo, "Saturation" ; > (10 chars, maybe 11) "Saturation"
TCODE tGasNeedsAscent, "Gas Needs Ascent" ; "Besoins Gaz Ascent" ; (19 chars)
"Besoin Gaz DTR" or "Besoin Gaz Remontée"
TCODE tgaschange, "Change?" ; better gas found ; (9 chars) > "Best Gaz" or "Meilleur Gaz" or "Changer ?"
TCODE tNeed, "Need " ; gas need ; (5 chars) > "utile" or "Besoin" or "Need"
TCODE tTransmitter, "P.Transm." ; pressure transmitter ; (9 chars) > "P. Sonde" or "P.Transm."
TCODE tswap, "Swap Tank" ; swap tank (9 chars) > "ChangBloc" or "Troc Bloc" > What is the context ?
TCODE tDiveTurned, "Dv.turned" ; dive is turned (9 chars) > What is the context ?
"Plg Ratée" (In the sense: diving failed)
or "PlgéLoupé" (In the sense: diving failed)
; Reset menu ; "Menu RaZ"
TCODE tResetSettings, "RaZ Settings" ; Reset Settings (19 chars) > "RaZ Paramètres" or "RaZ Data"
; Logbook Offset Menu; "Menu Carnet" or "Menu Logbook"
TCODE tLogOffsetValue, "Offset : " ; Offset ; (14 chars incl ":") > "N°1ère Plongé:" or "Ordre Carnet:" or
"Offset :"
TCODE tLogOffStepSize, "Step Size: " ; Step Size ; (14 chars incl ":") > "Taille de Pas:"
Cheers ;)
Hi Claude,
great work - great thanks to you & Didier as well !!!
Also received your mail via forward by Matthias, so i'm taking turn now putting it in...
