hwOS Tech: Version 3.05 released
The new hwOS tech (for OSTC3, plus, cR, OSTC 2 and OSTC sport (mod. 19)) firmware 3.05 is now available for download:
The version has many new features and changes, but the basic settings have not changed much since 3.01 and OSTC experienced users will be fine with it at once. However, we recommend that you first read the release notes (appendix to this post) and familiarize yourself with the new features. By popular request some settings have been extended and added. Thus the gas change is suggested again independently of an actual deco stop at the change depth and also the maximum ppO2 can be set beyond 1.6bar. As always, this applies here: Changes to the basic settings via accepted limits (GF>100, ppO2>1.6) are the responsibility of the user. In order to correctly forecast the TTS even when using more than one or two decogases (OC), a little more care must now be taken in the gas setup for such dives. For example, the MOD/change depth must also be set for the start gas (First) so that the OSTC can propose and predict all gases in the correct order. However, this still applies unchanged: Each gas from the gas list can be selected at any time in the dive. Unsuitable gases are already marked red in the gas list and a warning/recommendation is issued when selecting. The control remains however to 100% with the user.
Die neue hwOS tech Firmware 3.05 (für OSTC3, plus, cR, OSTC 2 und OSTC sport (mod. 19)) ist jetzt zum kostenlosen Download verfügbar:
Die Version hat zahlreiche neue Funktionen und Änderungen, in den Grundeinstellungen hat sich jedoch nichts Grundlegendes zur 3.01 geändert und mit dem OSTC erfahrene Benutzer werden gleich damit zurecht kommen. Wir empfehlen jedoch zunächst die Release-Notes (Anhang an diesen Post) zu lesen und sich mit den neuen Funktionen vertraut zu machen. Auf vielfachen Wunsch hin wurden einige Einstellmöglichkeiten erweitert und hinzugefügt. So wird der Gaswechsel wieder unabhängig von einem tatsächlichen Dekostopp auf der Wechseltiefe vorgeschlagen und auch der maximale ppO2 lässt sich über 1,6bar hinaus einstellen. Wie immer gilt hier: Veränderungen an den Grundeinstellungen über anerkannte Limits (GF>100, ppO2>1,6) liegen in der Verantwortung des Benutzers. Um die TTS auch bei Verwendung von mehr als einem oder zwei Dekogasen (OC) korrekt zu prognostizieren muss bei derartigen TG jetzt etwas mehr Sorgfalt im Gas Setup angewendet werden. So muss z.B. auch für das Start-Gas (First) die MOD/Wechseltiefe eingestellt werden damit der OSTC alle Gase in der richtigen Reihenfolge vorschlagen und vorausberechnen kann. Hier gilt aber weiterhin unverändert: Jedes Gas aus der Gasliste kann beim TG zu jedem Zeitpunkt gewählt werden. Unpassende Gase sind dabei schon in der Gasliste rot markiert und bei auswählen wird eine Warnung/Empfehlung ausgegeben. Die Kontrolle bleibt aber zu 100% beim Benutzer.
Tastenchef
Re: hwOS Tech: Version 3.05 released
Fantastisch es ist da das Update!
Eben installiert
Es scheint ein Problem mit dem Akku zu geben falscher Typ?
OSTC 2 17192
Hardware
33-51-3F
Batterie T4
Anzeige 99% bei 3.2V
Die angezeigte Spannung fällt schnell ab.
Ab 2.6V geht der TC aus (Zeitraum ca. 2 Minuten).
Eben installiert
OSTC 2 17192
Hardware
33-51-3F
Batterie T4
- ClaudeDive
Tip Top !!! Thanks Matthias & Ralph For this big job ...
In French replace "v_3.05 release" by "V_3.05 stable"
Many Thanks
Many Thanks
-> T4 ist schon korrekt für deinen OSTC. Über Nacht aufladen, der Akku ist leer und wenn es mal leer war muss der OSTC (Unabhängig von der angezeigten %-Zahl) geladen werden. Danach stimmt die Anzeige wieder weil der Batteriemanagement-Chip "weiß" wie voll die Batterie ist.
Christophe
Bonjour la team,
Ce matin j'ai installé la v3.05 FR sur mon OSTC 2 #16933 et je viens de plonger avec en OC en loisir.
J'ai apprécié :
- le nouvel affichage pour les paliers obligatoires qui sont maintenant mis en évidence,
- Le message "montée lente" à l'issue du dernier palier obligatoire".
Merci pour le travail que vous faites et les évolutions que vous apportez constamment.
Bonnes plongées à tous.
J'ai apprécié :
OSTC 2N, OSTC 2C, OSTC 2NE, OSTC 2, OSTC 2 5G Tech
Updated today. All looks good so far.
Gestern erfolgreich Update von 3.01 auf 3.05 durchgeführt.
Bei der Kalibrierung des Kompass ist der OSTC2 dann eingefroren, keine Reaktion mehr
Gestern erfolgreich geupdatet (3.01 --> 3.05, 40% Batterieladung) danach Batterie aufgeladen - eingeschalten (99% Batterieladung) alles scheint normal - heute morgen keine reaktion mehr - lässt sich nicht mehr einschalten - reagiert auch nicht auf aufladen - tot. hat das einen zusammenhang mit dem update?
gruss
Fredy
gruss
Fredy
> durchgeführt.
Wenn Du den OSTC bewegst, bewegen sich dann die Werte bei X,Y und Z jeweils? Oder steht "nur" die Zeit?
> durchgeführt.
Hallo Matthias
> Zeit?
Der OSTC war komplett eingefroren. Da haben sich keine Werte geändert.
Zum Zeitpunkt des Updates hatte er noch ca 74% Akku - gestern Abend ist er dann ausgegangen. Hab ihn noch nicht wieder geladen.
Das Update verlief auch ohne Probleme. Anschl. habe ich in den Einstellung die Große Ansicht ausgewählt und dann ein Simulation durchgeführt. Anzeige wieder zurückgestellet -> Simumalation.
Dann Kompass Kalibrierung, da ist er dann eingefroren.
VG
Thomas
> Zeit?
VG
Thomas
Ich hatte ebenfalls den selben Fehler des Einfrierens nach dem Update und der Kalibrierung des Kompass.
Ich lies den Computer einfach entladen, weil, schaltete sich ja ehe nicht ab.
Computer war dann aus gewesen. Lud ihn ca 10 Minuten auf der Ladestation auf und konnte ihn somit wieder einschalten. War im normalen Modus gewesen.
Ich setzte seine Funktionen alle wieder zurück in Ausgangsmodus, jedoch das Update war ja immer noch drauf.
Ich versuchte ihn vor dem Recover auf die alte Version up zu daten, was jedoch nicht möglich war. Erst nach dem Recover konnte ich ihn auf die alte Version zurücksetzen und werde ihn diese Woche testen. Den Kompass konnte ich somit auch kalibrieren.
Ich hoffe, alles richtig gemacht zu haben, und hoffe auf einen nun endlich funktionierenden guten Tauchcomputer. Vom Produkt selber bin ich ja überzeugt. Kleine und doch viele tolle Funktionen
Hoffe geholfen haben zu können.
Zur Info:
nach ca. zweieinhalb Tagen war der Akku leer. Hab den OSTC ein paar Minuten aufgeladen: startete dann mit der Auswahl des Akkus. Nach einigen Minunten startete der OSTC dann "richtig".
der Fehler konnte nicht nochmal nachgestellt werden.
Alle Werte/Einstellungen sind noch vorhanden.
Vielleicht hilfts für die Ursachensuche.
VG
VG
nicolas.villatte
Hi I have installed firmware 3.05 EN on OSTC Plus TECH.
After successful install and reboot it freezes.
Removing the battery and rebooting allows to reach menus, but after some time it freezes again.
Installing 3.05 FR different inconsistent behavior: somtimes it freezes after reboot, sometime I get it working but not bluetooth mode anymore, sometimes it works until charging and stays black screen and sometimes it just go to black screen and freezes.
I can install firmware from mobile phone/bluetooth but I am unable to connect via PC/bluetooth with OSTC companion. I am however able to connect with same PC/bluetooth for retreiving logs with Diving log application.
I had to downgrade back to firmware 2.98 I had on my phone to have it working properly again.
