Ostc2 V3.05
Erik69
Ostc2 V3.05
Post by Erik69 »
Hello
Something strange happened on the lat version v3.05.
I have no deco
The saturation stays 0%
And when I run a deco calculation
54m 40minutes the tts stays at 0
The other point is thatmy dive is in the logbook, but I don't see it with subsurface...
Any helo?
Eric
OSTC 2 #10039 v3.07
Re: Ostc2 V3.05
Apnoa/Gauge mode active?
Re: Ostc2 V3.05
when the deco calculator doesn't calculate a deco schedule although by depth & time there should be deco, you can probably fix this by doing a "Reset Deco" from the reset menu. This is certainly only a work-around, investigation of the real root cause is still ongoing...
Erik69
Re: Ostc2 V3.05
Post by Erik69 »
Hi
After disussion with Ralph,it has been solved with a reset deco
Eric
OSTC 2 #10039 v3.07
