I've stumbled over a problem that I think is related to the simulator in 3.07 Tech, but I'm not fully sure and I haven't been able to test live yet on my OSTC 2.
When running simulator with the large font setting enabled, I get a small green&yellow text on top that say e.g. 21m. This number seem to match the current "set value" for the simulator, i.e. when starting the simulator with default settings a dive targeting 21m is launched. From second zero, the green/yellow text show 21m while the actual depth is slowly increasing from zero to 21m.
When descending/ascending, the green/yellow text is updated to the new depth "set value" and after a while the current depth has been adjusted.
That said, what I fail to get working (at least in simulator mode) is to show both Max depth, Total average and Stopped average on the same display.
I need to choose between Total average and Max depth.
When using the unit with normal font size, depth and max depth is shown on top and total average and stopped average is shown in the middle.
See links to screen shots below...
Is this merely a simulator bug or is the same problem also present in water when using large font mode? I can live with the simulator showing strange values, but I would surely like to be able to use the grumpy-old-diver-mode in the water...
/Jonas
Large font in simulator
Standard font in simulator
