hwOS Sport: New Firmware 10.63
The new hwOS sport firmware 10.63 is now available for download:
This update is strongly recommended for all users of the 10.56 or later:
BUGFIX: Hardware versions 13-xx-xx and 58-xx-xx could hang up with versions of 10.56 or later
BUGFIX: Add surface part at end of dive to surface interval properly
BUGFIX: Average depth in logbook did not took salinity setting into account
CHANGE: Change color of temperature values in logbook to yellow
[10.60]
BUGFIX: Surfacemode could freeze in some hardware versions
BUGFIX: Potential issue with Bluetooth in older OSTC sport models
CHANGE: Default language in EN/DE version is English again
[10.58]
BUGFIX: Version number was not shown in main screen
BUGFIX: Button function could be toggled on charger
10.57:
BUGFIX: NDL in big font display
BUGFIX: Bluetooth mode in old OSTC sport (Red buttons)
10.56:
NEW: Five gases instead of three
NEW: Optional, 2nd Tissue graphic with markers for GF_low, GF_high and M-Value
NEW: Complete new Deco Planner and OSTC Simulator
NEW: 2nd Deco plan can calculate "Gas needs" (Optional) for all gases in real-time
NEW: Optional "Gas change time" and selectable extended stops (Shifting the gas change to the first real deco stop)
NEW: Configurable ascend speed
NEW: Support for more hardware versions (OSTC sport and 2 TR)
NEW: 2nd Layout (With larger fonts and slightly less information)
CHANGE: Deco plan is updated much faster
NEW: Information menu shows hardware version
It contains RX firmware 1.39 for all OSTC 2 TR users.
Die neue hwOS sport Firmware 10.63 ist jetzt zum kostenlosen Download verfügbar:
Für alle Nutzer der 10.56 oder später ist dieses Update dringend empfohlen:
BUGFIX: Hardware versionen 13-xx-xx und 58-xx-xx konnten einfrieren für alle Versionen 10.56 oder später
BUGFIX: Der flache Bereich am TG-Ende wurde nicht zum Oberflächenintervall addiert
BUGFIX: Die Durschnittstiefe im Logbuch wurde ohne den eingestellten Salzgehalt angezeigt
CHANGE: Temperaturwerte im Logbuch werden jetzt in gelb angezeigt.
[10.60]
BUGFIX: Oberflächemodus konnte bei bestimmten Hardwareversionen einfrieren
BUGFIX: Mögliches Bluetooth Problem beim alten OSTC sport (rote Taster)
CHANGE: Standard-Sprache in der EN/DE Version ist jetzt wieder Englisch
[10.58]
BUGFIX: Versionsnummer wurde im Oberflächenbildschirm nicht angezeigt
BUGFIX: Taster konnte auf dem Lader "durchrollen"
[10.57]
FIX: Nullzeit im Großbildmodus
FIX: Bluetooth bei alten OSTC sport (Rote Taster)
[10.56]
NEW: Fünf statt drei Gase
NEW: Optionale, 2. Gewebegrafik mit Markern für GF_low, GF_high und M-Value (Details: https://heinrichsweikamp.net/downloads/ ... GF_web.pdf )
NEW: Neuer Dekoplanner und Simulator
NEW: 2. Decoplan kann jetzt auch in der hwOS sport eine Gasverbrausberechnung über alle Gase durchführen
NEW: Optional konfigurierbare "Gas Wechselzeit" und "Erweiterte Stops" (Der Gaswechsel kann auf den ersten echten Dekostopp verschoben werden)
NEW: Konfigurierbare Aufstiegsgeschwindigkeit
NEW: Unterstützung für neuere Hardwareversionen (OSTC sport und 2 TR)
NEW: 2. Layout mit großer Schrift (Und etwas weniger Informationen)
CHANGE: Dekoberechnung ist wesentlich schneller geworden
NEW: Informationsmenü zeigt Hardwareversion an (Für besseren Support)
Es enthält die RX firmware 1.39 für alle OSTC 2 TR Benutzer.
How to install: https://forum.heinrichsweikamp.com/view ... 5f630b93c2
Finewine
Re: hwOS Sport: New Firmware 10.63
Post by Finewine »
When 10.60 came about i didn't like the layout and with some of the software problems encountered, I chose to revert back to 10.53, which I had got used to and understood etc.
As there is now a 10.63 version and with only a few dive likely throughout the winter months,I'll have time to get used to and understand any changes but is everyone out there OK with this new version and the changes that have been made??
I did and will express my concerns that the 'upgrades' to the Sport were a little over the top for what is a recreational divers computer and that if ALL of the features available were being used, has the diver actually got the right computer??
Never forget the acronym KISS.....Keep It Simple, Stupid.
If it helps, I'm a BSAC Dive Leader and Assistant Instructor with just shy of 500 dives in many varied enviroments and conditions that the UK has to offer as well as plenty of warm water dives.
What are the thoughts of you recreational divers out there????
Slinger65
Post by Slinger65 »
It took me a couple of hours to get my OSTC Sport connected, due to the seemingly 'normal' connection issues, but the upgrade to 10.63 appeared to go ok. However, the data for Dive Log Offset, gas list and device name etc have all been lost. I still can't set the device name because I can no longer get my Sport connected - now I am getting an error message from OSTC Companion saying that my device is not an OSTC Sport.
Any help here would be appreciated.
Re the question posed by Finewine on complexity, I think dive computers are becoming generally more complex and the Sport is bridging the gap between recreational and technical. Generally, many divers do not spend enough time getting to know what their computer is telling them and then understand what they should be doing with that information. As a DM with 500+ dives I would like to see greater emphasis on understanding dive computers included in early diver training.
Choose "OSTC 3+" in the Companion. We have a new companion coming which only distinguishes between USB and Bluetooth OSTC.
The new hwOS sport code is now 100% based on the TECH code and so the units are identical to the external software. That allows software providers an easier integration of the units since they no longer have to make special code for the hwOS sport or tech version. A side-effect is, that the hwOS sport now got a lot of features which were in the hwOS tech before. Like 5 gases and aGF.
Slinger65
Post by Slinger65 »
Many thanks Matthias. I'm connected and I've applied the changes I need.
