The set/menu button on my mk.2 is not very sensitive a lot of the time - needs a hard push. The other day, I used it when it was plugged into the charger and the button is really sensitive.
I was wondering if it's more sensitive because of the higher voltage, and whether the battery might be a bit tired and that's what is causing the unsensitive button. The battery info page says Cycles 287 (102) and lowest Vbatt: 3.931V.
Is replacing the battery likely to improve the button sensitivity?
OSTC Mk.2 Button Sensitivity
Re: OSTC Mk.2 Button Sensitivity
The buttons in the Mk.2 are not adjustable and unfortunately not replaceable. Sensitivity is not depended on the battery voltage (Internal voltages are regulated).
Thanks. I was just interested that the sensitivity is a lot higher when the battery is charging. Is this just a conincidence?
