OSTC 2: Battery 99% after Empty Battery (T4)
Spacefish
Post by Spacefish »
i stored my OSTC 2 (built in battery) for a long time (> 12 month) and the battery ran flat (did not turn on).
After putting it on a charger, it turned on via the bootloader (blue "play" button displayed). Afterwards it asked for the battery type. I selected "OSTC 2 / TR (T4)"..
Now it´s saying 99% 3,2V.. So essentially the battery is empty, but it´s showing 99% state of charge.
This is really bad IMHO, as it looks like a full battery, when the battery is not full. So you might go diving without realizing that you battery will run out within seconds / minutes.
Proposed change:
- Assume Battery empty if voltage < 3,7V and battery charge status is "unknown". Just do normal charging logic till 4,2V.. When 4,2V is reached just set it to 100%.
At least don´t asume 99/100% if the state is unknown.
Maybe even introduce an "unknown" charge state and only assume 99% / 100% if fully charged once.
Info regarding my OSTC
Firmware: 3.12
Serial: 15832
Re: OSTC 2: Battery 99% after Empty Battery (T4)
We have a rather large warning about this behavior in the manual for many years now. But with many users now starting to use the OSTC again after >2 years of storage this is currently a common question here at our support team.
If the battery of the OSTC was discharged,
the OSTC should be charged overnight (at
least 6 hours), regardless of the percentage
value displayed. It is important to set the
correct battery type in such a case, even for
OSTCs with a permanently installed battery.
Spacefish
Post by Spacefish »
Ich weiß schon das es so ist und das man die Batterie trotzdem volladen kann / muss.
Fände es nur cool, wenn die Firmware erstmal von einer leeren Batterie ausgehen würde und dann eher auf 99% / 100% springen würde, wenn 4,2V erreicht sind o.Ä. b.z.w. wenn halt kein Strom mehr fließt beim Laden (keine Ahnung ob ihr ein current sensing habt) jedenfalls für den Typ "integrierte Batterie".
Alternativ auch, dass es einfach einen "unknown charge" state gibt, wenn der Ladezustand nicht bekannt ist (für alle Batterietypen) und dieser erst auf 99%/100% gesetzt wird wenn die Batterie einmal per Puck vollgeladen wurde / der Ladezustand bekannt ist.
Beim aktuellen Verhalten ist halt das Problem, dass Leute evtl. ins Wasser springen, weil 99% dransteht und in Wirklichkeit die Batterie aber knapp vor leer ist.
Habe ich jetzt auch schon mehrfach von unterschiedlichen Leuten am See gehört, alla: "Verdammt mein Tauchcomputer ist einfach ausgegangen", z.B. von zufälligen Tauchern am Attersee. (sie hatten einen OSTC mit Wechselbatterie).
Eine andere Lösung wäre noch einfach Spannungslevel für die unterschiedlichen Batterietypen anzunehmen, ab denen die Batterien als "voll" betrachtet werden, wenn Sie neu eingelegt werden. z.B. >= 3,75V bei einer 3,7V Lithiumzelle.
Jedenfalls nicht 99% anzeigen, wenn als Typ eine Zelle ausgewählt ist, die eigentlich 3,7V Nennspannung hat aber gerade nur noch 2,x oder 3,2V oder so.. Denn dann weiß man zu 100% das diese nicht 99% geladen ist.
Leute lesen keine Bedienungsanleitungen, wenn doch vergisst man das Verhalten meist trotzdem, wenn man sich 2-3 Jahre später dran erinnern müsste.
