Strange USB/Bluetooth Behaviour OSTC 2
Clownfish
Post by Clownfish »
I have an OSTC 2 running the latest firmware 3.20. I have just noticed a strange thing relating to the Bluetooth option in the menu.
I have not yet figured out what causes this change, but what happens is that sometimes the option says Bluetooth and at other times it says USB. Even if it says USB, the Bluetooth still works.
When I have one gas as First, another as Deco the Bluetooth option in the Settings Menu actually reads USB. If I make a Work gas as well, it changes to Bluetooth. If you make the Work gas Disabled, it changes back to USB. To see this happen you have to go right back to the main screen and then enter the menu again. Very strange!!
Michael
Sydney Australia
Re: Strange USB/Bluetooth Behaviour OSTC 2
This bug is well known, have a look here : viewtopic.php?t=22368&sid=441277ace47c7 ... df287c3df5.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Clownfish
Post by Clownfish »
Thank you, had not seen that one, but was in German so might have missed because of that. As long as it is known. I only had it happen since latest firmware.
