OSTC 3 only USB no BT
TUC
Post by TUC »
my OSTC 3 allows BT data transmission but only USB. this happens with all the firmware that I have
3.17
3.19
3.20
3.21
Furthermore, if the companion SW works perfectly, Planner does not see the machine and does not allow me to change the settings (version 2.7.5 for mac) how can I fix it?
Re: OSTC 3 only USB no BT
"my OSTC 3 allows BT data transmission but only USB" : could you clarify ?
"Planner does not see the machine and does not allow me to change the settings (version 2.7.5 for mac)" : you should better post this on a Planner forum.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
TUC
Post by TUC »
sorry for my english. I try again to explain the problem:
when I access the menu where the BT function should be activated this is not displayed
the problems i have with planner are secondary to the BT not working.
TUC
Post by TUC »
help :roll:
heinrichsweikamp3
Site Admin
Post by heinrichsweikamp3 »
Just ignore the naming, this menu will start bluetooth just fine.
TUC
Post by TUC »
even if I can't find any trace on the manuals I think there are two versions of ostc3. One that connects via USB (only) and one that connects with BT. My USB menu if the cable is not connected does not open any submenus. what my OSTC2 did instead, this:
I replied to your other post on July 16th : viewtopic.php?p=24336#p24336.
Regards.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
