The new hwOS tech firmware 3.37 is now available for download:
https://hwdiving.com/firmware/?lang=en
Using OSTC+ or OSTC cR with external O2-Monitoring? Make sure to install the firmware with "_cr_" in the file name to keep the O2-Monitoring option available!
[3.37]
MD5: 030571809e45b2ab309a20b736a1142c
NEW: Add color-coded battery voltage as an additional warning for a low battery (3,6V rechargeable only)
NEW: Additional information page with technical information about the logbook storage memory
[3.36]
MD5: 5e8dce56f51d8a166dc33422f4a69831
NEW: Support for new hardware versions (OSTC+ only)
BUGFIX: Update/Download in OSTC nano hardware improved (Tech version only)
[3.34]
MD5: d651a4c35c65c014fa9b6cb52b825eeb
BUGFIX: Compass showed 000 when dive mode was started out of sleep mode
BUGFIX: String "Höhle" was not properly shown (German version only)
BUGFIX: Digital S8 Interface could delay startup on OSTC+ S8 in rare caes
[3.33]
MD5: 2d43f4dac2c2875e1c6269df2102c8e8
BUGFIX: Time/Surface pressure Customview was missing in dive mode
BUGFIX: Some hardware versions showed pressure fluctuations when compass display was initialised
[3.32]
MD5: 448cce977c0b2971b902d32013323319
NEW: Scrubber timer. Counts down during CCR dives and gives a warning if a) timer is <30min or
timer < TTS of the current dive. Enable and configure in CCR/pSCR Menu. Scrubber is shown
in Surface Customview and in the CCR/pSCR Menu
NEW: Support for "OSTC nano" hardware
NEW: Surface GF. Shows Surface GF for instantaneous ascend to the surface. Selectable in the custom view area
CHG: Hide buttons menu for hardware where buttons are not adjustable
[3.31]
Beta release
NEW: Add Custom View with Saturation (Called "GF99" by others), Ceiling and Surface GF
[3.30]
MD5: 8316baf84e49e5f8e87b3a2dfc43f435
BUGFIX: After a power-on reset, some hardware versions would enter divemode delayed for the first dive
[3.29]
MD5: b22396d1d3f973c8ec41f7a7e00da939
[3.28]
MD5: f7960ecc2f353361dcf7e598dd460cc6
BUGFIX: Compass on very old OSTC 3 hardware was inactive in the 3.27
[3.27]
MD5: 33bbe464b0d76a59dd6833167244dbe8
NEW: Quicker startup
CHG: Slightly reduce sleep mode consumption
NEW: Compass now uses much larger font for heading display, removed clutter and graphics making the compass more useful
NEW: Compass uses dedicated stopwatch. It's reset and restarted when a course is set
NEW: Temperature still shown during compass use
[3.26]
MD5: 16e150139c3b28af38b24a05f87c0b86
BUGFIX: Year in internal Time/Date menu was limited to 2024
[3.25]
BUGFIX: Firmware recovery for hardware versions xxxx-xx05
BUGFIX: Plain Bühlmann (non-GF) could show a stop 0min @ 0m
CHANGE: Color design updated in surface mode
NEW: Additional customview Desat/NoFly/CNS added in surface mode
[3.24]
CHANGE: Add voltage-based battery meter for OSTC+/PLUS when inserting batteries with unknown SOC
CHANGE: Compatibility for new hardware versions
CHANGE: Language updates
BUGFIX: Release and "Update" dates fixed
[3.22]
FIX: minor fix of 12h time update in dive mode
NEW: Add charge cycle counter
NEW: Add surface customview 11: NoFly, Desat and CNS
NEW: Show # of descends in Apnoe mode
CHANGE: do not show the "slow" in the alternative layout
CHANGE: minor adjustment of depth position in large layout
[3.21]
FIX: Wrong release date in 3.20 showed "Update!" message prematurely
CHANGE: Reduce default bottom time for simulator from 10' to 2'
FIX: BLE was on after first reboot (until sleepmode kicks in)
Details on hwOS: https://hwdiving.com/hwos/?lang=en
How to install: viewtopic.php?f=6&t=14509
Die neue hwOS tech Firmware 3.37 ist jetzt zum kostenlosen Download verfügbar:
Du verwendest einen OSTC+ oder OSTC cR mit externem O2-Monitoring? Installiere unbedingt die Firmware mit „_cr_“ im Dateinamen, damit die O2-Monitoring-Option verfügbar bleibt!
[3.37]
[3.36]
[3.34]
[3.33]
[3.32]
[3.31]
Beta release
[3.30]
[3.29]
[3.28]
[3.27]
[3.26]
[3.25]
[3.24]
[3.22]
FIX: Kleine Korrektur in der 12h-Zeitanzeige (AM/PM) im Tauchmodus
NEW: Ladezykluszähler hinzugefügt
NEW: Benutzerdefinierte Oberflächenansicht 11 hinzugefügt: NoFly, Desat und CNS
NEW: Anzeige der Anzahl der Tauchgänge im Apnoe-Modus
ÄNDERUNG: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: das "slow" wird im alternativen Layout nicht mehr angezeigt
ÄNDERUNG: Kleine Anpassung der Tiefenposition im großen Layout
[3.21]
FIX: Falsches Veröffentlichungsdatum in 3.20 zeigte verfrüht "Update!
CHANGE: Kompatibilität für neue Hardware-Versionen
ÄNDERUNG: Standard-Bottomtime für den Simulator von 10' auf 2' reduziert
FIX: BLE war nach dem ersten Neustart eingeschaltet (bis der Sleepmode einsetzte)
Bitte Fragen zum Update/Probleme beim Update in einem neuen Thread posten.
Details zu hwOS: https://hwdiving.com/hwos/
Anleitung zur Installation : viewtopic.php?f=6&t=14509
hwOS TECH: New Firmware 3.37
The hwOS firmware manual is from January 2021 (hwOS tech 3.13), it's largely obsolete now. Many features have been added and would take benefit of a complete description.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
Re: hwOS TECH: New Firmware 3.37
Hi Heinrich,
I have downloaded release 3.38 with HW Config on Android.
Any way to do the same with iPhone ? HW Config unknown (?)
Directly from your website ? HOW?
Thanks for your prompt reply.
Yves
Yves
Try "OSTConf" on the iPhone.
The archive v_338_hwos_firmware.zip contains only several 388_XX_3_XX_ostc3_firmware.hex files, no 388_XX_2_XX_ostc3_firmware.hex. Does it mean this release is not available for OSTC without O2 sensors ?
I did install 388_fr_3_tr_ostc3_firmware.hex on my OSTC 2 (#188835), a calibration menu is displayed, but this is meaningless for this computer.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
It doesn't matter for your computer but for units with external O2 monitoring interface the *cr* version is required. See readme.txt in the firmware archive.
I did it ! Here is an excerpt from this file :
???_DE_2_tr_ostc3_firmware.hex German Version
???_EN_2_tr_ostc3_firmware.hex English Version
???_IT_2_tr_ostc3_firmware.hex Italian Version
???_FR_2_tr_ostc3_firmware.hex French Version
For OSTC cR, OSTC+ and OSTC 3 with O2 Sensor functions use
???_EN_3_cr_ostc3_firmware.hex English Version
???_DE_3_cr_ostc3_firmware.hex German Version
???_FR_3_cr_ostc3_firmware.hex French Version
???_IT_3_cr_ostc3_firmware.hex Italian Version
Maybe ***2_tr_*** files have been wrongly named ***3_tr*** ?
Regards.
Regards.
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
OSTC 2 #19005
-OSTC 2 #18835
-- OSTC Plus #16077
--- OSTC 3+ #4806
---- OSTC 3 #3999
