Just run a simulated dive 45m/25'. Tried only AIR and AIR + NX50 - got exactly same deco profile for both, which seems a bit strange.
I am sure that gases are taken into consideration in the normal dive mode, as switched them several times and deco was nicely recalculated. Why wouldn't it be included in the original dive simulation ?
That's what I got from simulator.
45m/25', GF20/80
21m/4
18m/3
15m/4
12m/6
9m/9
Simulator - deco gases not taken into account ?
Kind regards,
Gorcio, OSTC MK2 828
Re: Simulator - deco gases not taken into account ?
Sure that your deco gaz is
(i) active
(ii) the depth is entered
If it's inactive or the depth is 0m you won't get it in the simulation.
(i) active
> (i) active
Absolutely sure. Just took it out of water, where it was used and set up properly for a dive. It's both Active, and has it's depth set (21m for NX 50)
> (i) active
Kind regards,
sander
hello,
the same problem do I have.
and there is a other post/message about this problem.
gr sander
gr sander
Tom
I already posted the same remark myself in another thread.
I have another question also. I just received the machine last week and family stuff is keeping me dry till end of the month so i just had a chance to play with the simulator...
When set to GF it seems pretty unsure about its deco obligations. It goes from 1min@6 to zip and back for like 2 minutes over and over again, then it adds a 9m stop, it changes its mind and ads a 12m stop, goes back to 9 , then to 12, then it thinks it should be 2 minutes at 9 and then goes straight to 15...
If this is the behaviour i can expect when diving i think we have a problem houston
Can anybody explain this to me or should i start debugging
I have another question i didnt find info on : when skipping deco there is a percentage indication displayed. What is the exact meaning of this cause this does seem like realy interesting to me for a diver who knows what he is doing ... If he knows what info he is being presented that is ofcourse ....
