VPM(-B) - any plans ?
Just wanted to check if You guys ever thought about having VPM implemented as well in the firmware ?
Kind regards,
Gorcio, OSTC MK2 828
Re: VPM(-B) - any plans ?
I'd like to know about it, too!
I hope it will be implemented.
And the absolute TOP would be if it could run GF and VPM in parrallel ...
Or even GF doubled, so you could set 2 different sets of parameters and then choose on the fly which profile you want to follow. This would enable you to have an emergency scenario without having to use a second computer just for that.
Do you think that you take full blown PC under water?
As far as I know the OSTC MK2 is not powerfull enough (procesor, RAM) to run VPM ! Not even doubled GF!
regards
regards
just reconfigure your computer to always display GF,
then follow the numbers... you will get enormous
amount of GF scenarios
Well, I tried that in simulator mode and it puzzled me.
the value didnt seem to make sense but i'll take a good look at it again
Either i flipped a bit last time i checked it our or there has been a bug fixed but it does make sense now. Mighty cool.
