Strange Values for No Fly
Solodiver
Post by Solodiver »
2h hours after the dive I had a no fly value of 65:34, what does this mean? I can't believe these are hours. I also had a smal vaulue for Desat, which is gone now. My saturation bar is complety empty now (80%) for N2 and HE, but I still have 63:something for no fly!? I did something like 20min@65m today using a light trimix in a CCR.
I'm currently running 1.81 but noticed this behaviour also some weeks ago (1.80 or the latest 1.7x release).
dmainou
Re: Strange Values for No Fly
Post by dmainou »
Check the desat cf.
OSTC MK2 1394
Solodiver
Post by Solodiver »
CF12: 90% (Default 90%)
After 5 days off the water now it shows 216:something, looks like a bug to me.
Updating to 1.82 now...
Solodiver
Post by Solodiver »
Most likely also broken in 1.82, switching to the 1.82 thread now...
dmainou
Post by dmainou »
Mate,
Wrong cf
You should be looking at cf 13.
OSTC MK2 1394
Solodiver
Post by Solodiver »
CF13: 60% (Default 60%)
As assumed by other guys as well in the 1.82 thread there seems to be some kind of problem. The no fly value shows now 68:13, seems correct in relation to the 70:xx before...
dmainou
Post by dmainou »
Try loading it from the pc software. it may well be 1060%
or from the pc reset all cf's and start all over again.
OSTC MK2 1394
There was a bug in the NoFly routine, please check the new beta (coming in the next days) about this issue.
Solodiver
Post by Solodiver »
Just for the records: After doing a shallow dive some hours later the no fly value is now cleared....
Rüdiger
Post by Rüdiger »
habe letztes Wochenende die neue Version 1.83 ausprobiert. Während des Tauchgangs war alles bestens. Die Anzeigen nach dem Tauchgang haben aber ein paar Fragen aufgeworfen.
- noFly - es wurden ca. 65h angezeigt,bei desat von ca. 34h und CF13 mit 60%,der Fehler scheint also noch vorhanden zu sein
- desat - unmittelbar nach dem Tauchgang waren es 34h, 2h später noch 21h und weitere 6h säter nur noch 7h
In dieser Zeit habe ich mich von 600müNN auf 200müNN runter begeben. Das sich bei Verringerung der Höhe die Zeit verkürzt, habe ich erwartet, aber so gravierend dann doch nicht. Mein 2. TC war von der Höhenänderung dagegen völlig unbeeindruckt.
Grüße
Rüdiger
Bardass
Post by Bardass »
The topic starts in english
Can you continue in english please ?
Thank you
Bardass
Solodiver
Post by Solodiver »
Rüdiger just stated again that there is something wrong. I think this topic is well known now and covered in the 1.83 Thread also, so we can stop discussing this in here...
JeanDo
Post by JeanDo »
Definitely a bug, high in my priority list (because sounds quiet easy to correct). In fact, the conjunctions of two:
- NoFly bad value just when you exit a dive.
- Doing a simulation (eg. just the default 1min@15m) reset the NoFly value to something correct (except it should not be reseted).
Thanks for the signaling.
Ekki
Post by Ekki »
the annoying blue led
beta V1.83
still the same "No Fly" bug......
Ekki
Bardass
Post by Bardass »
the same bug for me with 1.87 Beta
see PDF below
Bug No Fly v1.87 Beta
Bardass
