In der eben hochgeladenen Version 1.16 ist ein Background Debugger enthalten, welcher wichtige Daten liefert wenn der Divemode mit "Reset" ?ber das Interface abgebrochen wurde. Download hier: http://www.heinrichsweikamp.net/ostc/de/firmware.htm
Viele Gr?sse,
Matthias Heinrichs
In the just uploaded version 1.16 a background debugger is included which shows important informations if the Divemode was interrupted with a "Reset" from the interface. Download this version from here: http://www.heinrichsweikamp.net/ostc/en/firmware.htm
With kind regards,
Matthias Heinrichs
1.16
corona_citron
Re: 1.16
and what about the bailout gas for the PPO2 deco ?
You said me that you will add more in the next release....
Re: 1.16
Yes, already done. I published the 1.16 with the background debugger first because I was still testing the new bailout functions. In ppO2 mode, a new menu "Bailout" is now available and you can select all five bailouts from this menu. Instead of the ppO2 "Bail" is displayed showing that you are in OC mode then.
We will publish the 1.17 very soon (this week).
