New 1.88beta available
Another update, maybe one of the last before the new stable 1.90:
http://www.heinrichsweikamp.com/en/ostc_2n/firmware/
- Some bugfixes, especially the "Gas4" bug
- New +@xx minute variant. We named it "Future TTS":
Configure CF58 (0-10 minutes) and get the TTS in xx minutes assuming you hold the depth and stay with the current gas. Toggle this function with the "custom view" option (Enter button w/o active Menu) in divemode.
Ein neues Update, evtl. eines der letzten vor der neuen Stable 1.90:
http://www.heinrichsweikamp.com/de/ostc_2n/firmware/
- Einige Fehler wurden behoben, insb. der "Gas4" bug
- Ein Variante der +@xx Funktion. Wir haben es mal "Future TTS" genannt:
In der CF58 kann ein Wert (0-10 Minuten) eingestellt werden. Im Tauchmodus kann nun die TTS, die nach dieser Zeit berechnet wäre, angezeigt werden. Diese Funktion geht davon aus, das die aktuelle Tiefe und Gase beibehalten werden. Auszuwählen über die "Custom View" Funktion (Enter Taste ohne aktives Menü) im Tauchmodus.
Re: New 1.88beta available
thank you for the job
Beware : There is only one beta version before the 1.9 stable
Don't worry. If required it will be the "1.91 Stable"
Bzcktoth
Thank you very much for The @X function. It is really great!!!
No, it's bombastic
Thx sooo much guys!
No, it's bombastic
Thx sooo much guys!
> ohhh
> there is no french Hex in this beta ...
Correct... We'll post multi-language hex files for the stable again, of course.
Thx again Matthias!
Is it by purpose that it shows xx' when there is no deco? IMHO it would be better to show the TTS instead (which would be correct in the meaning "Future TTS"). It also seems that it is just start to calculating when there is a deco and not when the TTS is less than 5min.
I'm not sure about these two issues as I just use the simulator for now and I also get XX' for quite a long time when toggling the custom view. Is xx' is standing for "unknown" then "--" would be better in my opinion.
The ppO2 in the Live EAD/EAN Display is still "wrong" for CCR dives (see the 1.87 thread), I suggest to show the diluent ppO2 which is important to know for flushing and cell checking (ppO2 is the same as for OC).
The trailing space for EAD (when it gets below 10m while ascent) and for the Max depth (when crossing the 100m mark) is added.
I still do no know how to set a marker!?
Thx,
Thx again Matthias!
Thx,
Correct.
http://www.heinrichsweikamp.com/read.ph ... 8#msg-4638
Just checked - works fine.
Correct.
"Futur TTS" show xx'
* It means you have to wait for the computation. I'll probably write "wait", or "--" instead.
* Yes, computation is started only when there is already a deco. Bad choice. I'll change that.
* I'll write "no deco", as in the main TTS display, too.
Thanks for the remarks.
