Am I correct that when the simulator/decoplanner is run it is not affected by any diving history.
Therefore if I run it after the first dive of the day with the info for a second dive, the info from the first dive does not affect the output.
Simulator operation question
peppe.marsala
Re: Simulator operation question
mmmm... it sholud be affected by the desaturation time...
www.pinnanobilis.net
OSTC Mk2 1695
OSTC Mk2 1695
Assuming you have 1.8 or later installed, the tissue load from real dives is taken into account for the simulation, of course.
peppe.marsala
Which is the way it has to work
David, if you want to use a plain simulator then you have to reset your deco data before (but don't go for a ripetive dive
OSTC Mk2 1695
OSTC Mk2 1695
david tobin
Yes I have 1.9 installed.
Thank you for the quick response
