Display problem with the translation into French.
moi_xav93
Post by moi_xav93 »
Hello Matthias
I see a display issue with version 1.90 in French. The term "SansAvion"is too long. It turns out that the time display before taking the plane is no longer over the duration of desaturation. time beyond the parameter "OC". It is important to make clear the display. I think the term "SansAvion" should be replaced by "NoFly" or "Avion" to remain in French.
In advance thank you for your response to the update ;)
Cordially
Bye
Xavier
JeanDo
Re: Display problem with the translation into French.
Post by JeanDo »
Done by Matthias for the next 1.91 beta.
