tiny bootloader linux alternative
ungraven
Post by ungraven »
Does anyone know if Tinyul works for flashing the OSTC?
http://wiki.themel.com/tinyul
Re: tiny bootloader linux alternative
Currently, only JDiveLog can upload the firmware with Linux. Tinyul has not yet been tested from us, sorry.
After looking at Tinyul a bit more detailed, I think that this should work fine for the OSTC. You have to build the C definitions from icdpictypes.inc file (found in the windows package here: http://www.heinrichsweikamp.net/ostc/do ... loader.zip) with the perl script included in Tinyul to support the 18F4685 in the OSTC.
ungraven
Post by ungraven »
Thanks for the reply!
I had forgotten JDiveLog could flash, but it's good to know there's a couple of choices.
servan
Post by servan »
After updating the firmware to 1.19, I can't use Jdivelog.
Do you change the transfer protocol between 1.17 and 1.19 ?
Is tinyul the only way to make update on Gnu Linux ?
Servan
Hello Servan,
Make sure to set JDiveLog "File->Settings->Divecomputer->Driver" to OSTC Protocol "1.09-1.15" instead of "Auto" unless a JDiveLog update with the 1.19 support is available. 1.19 uses some new commands in the protocol but is backwards compatible to the existing JDivelog.
