ppO2 bottom / deco
Voss
ppO2 bottom / deco
Post by Voss »
I'm a brand new OSTC user so maybe what I'm asking here is already covered in the current software. But it seems to me that there is currently 1 parameter for high ppO2 warning, which applies to all gases. Is it possible (or maybe worth a feature request) to have 2 separate values, one for bottom and one for deco gases (like 1.4 / 1.6)?
Another question: I noticed that it is not possible to set an MOD for the 1st gas and I appreciate that there is no switching depth. Shouldn't it still be possible to set a maximum depth though? Also it seems that when the gas consumption is calculated in the simulator the result for the bottom gas is 0, probably because there is no MOD? Not a biggie because I cut my tables with V-Planner, but maybe this could be sorted as a cosmetic change at some point?
Having said that - thanks for an awesome product, keep it up! ;)
BR, Voss
Gucky
Re: ppO2 bottom / deco
Post by Gucky »
Hallo Voss,
Du kannst mit CF19 auswählen, ab wann der aktuelle ppO2 im Display angezeigt wird. Den Wert könntest Du auf 1,4 bar setzen.
Mit CF18 und CF46 kannst Du den Wert für ppO2 einstellen, der in der Warnfarbe dargestellt wird. Zum Beispiel auf 1,6 bar.
Der Gasverbrauch wird für alle aktivierten Gase des Tauchgang berechnet.
by google translator ...
Hello Voss,
You can choose to CF19, when will the current ppO2 displayed on the display. The value you could set to 1.4 bar.
With CF18 and CF46, you can set the value for ppO2, which is displayed in the warning color. For example, at 1.6 bar.
Gas consumption is calculated for all active gases from the dive.
Gruß Gucky
Voss
Post by Voss »
OK, German it is. ;) Vielen Dank, Dein Vorschlag ist ziemlich genau das, was ich mir vorgestellt hatte. Rote Warnung bei 1.4b bottom gas oder 1.6b deco gas waere mir noch lieber aber mit dieser Loesung kann ich gut leben.
Ich bin mir ziemlich sicher dass ich im Simulator beim Gasverbrauch hin und wieder mal "xxxx" b beim bottom gas gesehen habe, kann das aber im Mment nicht reproduzieren. Ist auch nicht weiter dramatisch, da ich fuer sowas V-Planner nehme.
Tausend Dank fuer die schnelle Antwort!
Voss
